tvenetis 1 #1 Posted October 25, 2025 I replaced the plug outlet on a tiny tiger generator and the white wire that goes to the plug broke off flush with the windings. I was wondering if some one has the stator that i can buy because it looks like the wire comes from the windings from the middle of the winding and there is no slack. Thanks Share this post Link to post Share on other sites
Wallfish 711 #2 Posted October 26, 2025 No slack at all. the "epoxy" or whatever it is holds and isolates the winding wires. You can pick it out carefully and solder the wire back but be sure to cover it again. Something like liquid electrical tape should work. 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #3 Posted October 26, 2025 A friend helped me and we soldered the wire and I put the generator together. It is not producing 120 volts. I even tried speeding ut up and no change. Share this post Link to post Share on other sites
Wallfish 711 #4 Posted October 26, 2025 That old epoxy is always cracked and brittle so moving the wires can expose the copper wire and cause a "short". Maybe use a meter to confirm the windings are not shorted to each other. Have someone look at this wiring pic for you. It's an open generator with the wiring 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #5 Posted October 26, 2025 I have a talking meter so put the meter leads on the wires that go to the plug outlet? Share this post Link to post Share on other sites
Wallfish 711 #6 Posted October 26, 2025 31 minutes ago, tvenetis said: I have a talking meter so put the meter leads on the wires that go to the plug outlet? The winding wires of the generator without anything connected to them. You should be able to figure out if something is shorted or if the wire is broken and not making a complete circuit. Then you can verify through the AC plug as the wires connect directly to that. Systematic detective work going through each circuit to hunt down where the issue is. It appears there are 2 separate set of windings. One for the AC and the other for the DC. Verify you are connecting the correct wires to each. Was the 12v DC working but not the AC? Share this post Link to post Share on other sites
tvenetis 1 #7 Posted October 26, 2025 I never checked if the dc was working. When I put the 2 probles of the meter in the plug socket and put it on continuity it beeped indication of a short. 1 Wallfish reacted to this Share this post Link to post Share on other sites
Wallfish 711 #8 Posted October 26, 2025 Carefully check where that wire was repaired. It's difficult to open that crusty stuff up without cracking more but just go slow. Solder with a solder gun and not a torch Check the other wires too as once you open it up and move them the insulation cracks easy. Share this post Link to post Share on other sites
tvenetis 1 #9 Posted October 26, 2025 We used a soldering gun to solder the wire. I do not understand why the black wire comming from the outlet branches off and connected to the diod with a wire nut that was crimped from the factory. Share this post Link to post Share on other sites
tvenetis 1 #10 Posted January 31 I bought another tiny tiger with a statur on it. After I remove the 2 screws and nuts what is the best way to remove it without disturbing the wires thanks. Share this post Link to post Share on other sites
Wallfish 711 #11 Posted January 31 Better to just remove it and repair the wires as no doubt they are crusty dry and brittle. Remove the rear two sections at once and the wires stay Share this post Link to post Share on other sites
tvenetis 1 #12 Posted January 31 I will try to remove both but how do you get the cap off that covers the bolt for the rotar? Share this post Link to post Share on other sites
Wallfish 711 #13 Posted Sunday at 03:06 PM You can get the 2 sections off without removing that hole plug cover 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #14 Posted 3 hours ago I separated the entire generator thanks. On the fuel tank why does it have a fuel line from one side of the tank to the other side as well as a fitting for the carburetor? Share this post Link to post Share on other sites
Wallfish 711 #15 Posted 2 hours ago 11 minutes ago, tvenetis said: I separated the entire generator thanks. On the fuel tank why does it have a fuel line from one side of the tank to the other side as well as a fitting for the carburetor? The shape of tank. The line from one side to the other allows air to escape out the top. Otherwise the opposite side from the fill neck would just remain an air bubble on the top without it. So that line allows it to fill all the space so the tank holds more fuel 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #16 Posted 2 hours ago does it matter where to connect the line that goes to the carburetor? Share this post Link to post Share on other sites
Wallfish 711 #17 Posted 2 hours ago Yes, one nipple will just suck air and the other has a stem to the bottom for fuel pick up Share this post Link to post Share on other sites
tvenetis 1 #18 Posted 2 hours ago Thanks II have to find the one that goes to the bottom. Share this post Link to post Share on other sites
