tvenetis 1 #1 Posted February 11 On putting the wire on the spool I can get the wire from the outside hole of the spool and feed it to the middle of the spool but how do you feed the wire down the center of the spool to come out of the other hole in the spool to make a loop for the rope. Share this post Link to post Share on other sites
Wallfish 715 #2 Posted February 12 The wire needs to be bent in such a way to feed both ends of the wire through the holes from inside of the spool out. The factory pieces resemble 1/2 a paper clip and the wire is kind of soft 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #3 Posted February 12 Can I use a paper clip or is that too heavy Share this post Link to post Share on other sites
Wallfish 715 #4 Posted February 12 Yes. Anything to hold the rope as long as it gets locked on the spool 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #5 Posted 20 hours ago I have the spring wound up in the round piece that comes with new springs and I set it in the recoil housing but how do you remove the holder from the spring thanks. Share this post Link to post Share on other sites
Wallfish 715 #6 Posted 16 hours ago 4 hours ago, tvenetis said: I have the spring wound up in the round piece that comes with new springs and I set it in the recoil housing but how do you remove the holder from the spring thanks. Hold the spring down with your thumb at the holder opening and pic out the holder with something sharp. Release the thumb pressure slowly so the spring unwinds slowly 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #7 Posted 15 hours ago I have to wind it up again. How do you wind it back in to the holder thanks. Share this post Link to post Share on other sites
Wallfish 715 #8 Posted 3 hours ago wind the spring and keep pulling on the tail to cinch it tighter and smaller. Repeat, repeat, repeat until it's wound tight and will fit in the holder. Share this post Link to post Share on other sites
tvenetis 1 #9 Posted 1 hour ago how do you hold the center from unwinding when you pull the end tighter? Share this post Link to post Share on other sites
