joegrgraham
Mountfield M1 coil.
Hi all,
Asking for a friend, he has just acquired a Mountfield M1, briggs engine.
Could anyone  advise on the correct coil for the engine?
Engine number in attached photo.
Thanks,
Joe.
Edited by joegrgraham
Miss spelling
You might be able to find a parts list on the briggs website,armed with the part number for the coil, search ebay for a replacement.Alternatively you would be able to get a genuine replacement from briggsbits they are UK based
You may be barking up the wrong tree as it is more likely to be the points need cleaning & failing that the condenser. These are located under the flywheel. His best bet is to get a magnetron from the 3.5hp Black Briggs engines that were fitted to many  16 - 18" mowers that have now rotted  away. He can then remove the old Magneto & cut the wires that go under the flywheel & fit the magnetron & never worry about points again.
Good advice about fitting a later Magnetron coil but the 130902 engine model number suggests a 5 hp engine which, I believe, may have a slightly different spacing between the mounting pillars from the suggested 3.5 HP donor for the coil.  Worth checking before buying.
The Magnetron equivalent to the original 298316 coil is 397358
