DCM
    17
About DCM
10,428 profile views
  1. Okay, I will try cleaning first. Are the parts available if needed? I`m assuming the ball bearing check valve is one piece with no actual ball bearing. Could it also actually be its getting too much fuel and the needle valve needs to be adjusted? Also the recoil pull cord is sluggish or slow and sounds like it needs lubrication or something. Throttle handle is broken but functional. It has a clamp around it, but want to be prepared in case it breaks. Thank you for responding its been four years since I first and last posted, i never really had the time to work on it. If you click on my DCM link it should take you to my post of the motor running. i couldn`t fit in this post.
  2. I did get this Aquabug running recently. I bought the gasket and diaphragm on ebay. I do have question on if anyone knows where i can purchase a throttle handle. The aquabug runs and sounds good but has a small leak coming from part of the carburetor, see in picture, i don't know what its called. any advice would be helpful. Also the starter pulley return sounds like it needs lubrication its slow to return and makes a lot of noise any advice would help. I`m sorry I haven`t responded because I just worked on it a couple of weeks ago. If it wasn`t for all your advice and help, I never would have got this running.
  3. I did get this Aquabug running recently. I bought the gasket and diaphragm on ebay. I do have question on if anyone knows where i can purchase a throttle handle. The aquabug runs and sounds good but has a small leak coming from part of the carburetor, see in picture, i don't know what its called. any advice would be helpful. Also the starter pulley return sounds like it needs lubrication its slow to return and makes a lot of noise any advice would help. I`m sorry I haven`t responded because I just worked on it a couple of weeks ago. If it wasn`t for all your advice and help, I never would have got this running.
  4. Great, this will come in handy when I get into this project. Thanks
  5. Yes, thanks, I agree. I was Skeptical, but I am still learning how to navigate this site.
  6. Edit by Factory: It's best to send personal details such as addresses/phone numbers etc. using private messages (PM), this can be found using the letter symbol at the top of the page if using a PC, or in the menu (three bars) if using a tablet/phone.
  7. Okay, I honestly didn`t expect all these replies.
  8. Hi, okay so that`s what i`m missing.
  9. Oh Damn, that is a bummer! Thanks for the info.
  10. Okay, so I will need that part also along with maybe a diaphragm. Who do you use for parts. I tried meatballbutch on ebay but couldn`t find any information. Are these parts available?
  11. Nice calm water out there at Cuttyhunk Island
  12. okay, I was looking in the wrong place I`m assuming this controls the air fuel mixture?
