tvenetis
    175
About tvenetis
14,372 profile views
  1. I sold everything except a tiny tiger generator which runs and I am trying to sell it on ebay.
  2. I have the spring wound up in the round piece that comes with new springs and I set it in the recoil housing but how do you remove the holder from the spring thanks.
  3. On putting the wire on the spool I can get the wire from the outside hole of the spool and feed it to the middle of the spool but how do you feed the wire down the center of the spool to come out of the other hole in the spool to make a loop for the rope.
  4. Thanks II have to find the one that goes to the bottom.
  5. does it matter where to connect the line that goes to the carburetor?
  6. I separated the entire generator thanks. On the fuel tank why does it have a fuel line from one side of the tank to the other side as well as a fitting for the carburetor?
  7. I will try to remove both but how do you get the cap off that covers the bolt for the rotar?
  8. I bought another tiny tiger with a statur on it. After I remove the 2 screws and nuts what is the best way to remove it without disturbing the wires thanks.
  9. We used a soldering gun to solder the wire. I do not understand why the black wire comming from the outlet branches off and connected to the diod with a wire nut that was crimped from the factory.
  10. I never checked if the dc was working. When I put the 2 probles of the meter in the plug socket and put it on continuity it beeped indication of a short.
  11. I have a talking meter so put the meter leads on the wires that go to the plug outlet?
  12. A friend helped me and we soldered the wire and I put the generator together. It is not producing 120 volts. I even tried speeding ut up and no change.
