danarmdave
Member at rest
    53
Everything posted by danarmdave
  1. Unfortunately Dave (the owner of all these saws) died last year and they are all up for auction through Pentland Livestock on 27th May. www.pentlandlivestock.co.uk
  2. danarmdave
    danarmdave
  3. model no k301/t spec 4749d serial no 9741752 the bonser no 620910 thanks dave k
  4. hi everyone does anybody know how to put a year to a bonser truck 1 ton model with kohler engine pull start or kick thank you
  5. hi put vivian loyd into google and the pictures of one that has been on this site come up cheers
  6. hi big bucks your petter engine looks like a att2 (a2 series 2) 1950s hope this helps
  7. before we bought it the guys young sons used it to cut a paddock they had horses in and he said it kept on breaking down but did not say what happened as the engine was ok it suggests to me the belt kept coming off as it was off when we picked it up thanks danarmdave
  8. hi i took it to the old guy at garden machinery place and he worried at it for about an hour and job done he just adjusted this /that and bent the belt guard to suit and as you say engage cutter before lowering was the first thing he said to me and he fitted a kevlar belt and seems to be working a treat now so fingers crossed thats it done thanks for everyones imput much appreciated danarmdave
  9. rebuilt /all metalwork done on top new bearings /new cutter blade /all new bolts ect /new belt
  10. decks just been rebuilt so is fine i might take it to the local garden machinery theres a guy whos been there since the sixties so he will maybe have an idea if not then charlies idea will be brought into force will try and get photos up monday as busy getting auction stuff ready for sunday thanks dave k
  11. well there is only one pulley on the cutting deck and it goes direct to crankshaft pulley no adjusters or pulleys to go round just an oval drive sam when the cutting deck is raised its fine but when you lower it to cutting position its not level the cutting pulley is lower and the belt just comes off
  12. yes sam they are thats is the prob
  13. no pics yet the prob is that the two pulleys are different heights the cutter being one and a quarter lower than the engine pulley and no way to level/adjust ???
  14. the belt is only round the cutter pulley then round the engine pulley there are no tensioners its just a large oval but the pulleys are different heights the tension is applied by engaging the cutter so when traveling the belt is slack and when in cutting mode its tightened but the height just kills it thanks dave k
  15. hi everyone sorry to trouble you but my cutting deck pulley and engine pulley dont line up when the cutters engaged and it then chews the belt and flicks it of i cant see ant way of adjusting or levelling the pulley any body out there any ideas many thanks dave k
  16. pentland livestock have an auction on sat 28th feb at coupar angus over 700 lots of everything tools /mowers /models /collectables to view www.pentlandlivestock.co.uk for all details and nearer 28th the full catalogue can be printed off thanks danarmdave auction held at lamb and gardiners garage
  17. hi morris leslie has one in his next vintage sale its described as 1965 wheelhorse kohler engine no 749239 expecting £100/£200 for it the sale is on 7th march at 10.30 google morris leslie vintage auction and its on second page thanks
  18. scottish autjumblers auction and autojumble on the 26 th april 2015 station road bridge of earn ph2 9ea opens to public at 10.00 admission £1.50 catalogue 50p auction starts at 12.30 lots to be in on saturday night if poss from 5.00 till late and sunday 8.00 till 9.00 as usual you never know whats going to come through the door tractor /horti /car /lorry /bike /motor cycle /stat eng /military /push bike /consumables /tools and everything else so its worth a look caterer on site plenty parking/ toilets if you have anything to put in lots can be picked up prior to the day (whithin reason ) no 100 mile trips any questions or queries phone dave on 07747165687 email danarmdave@btinternet.com for autojumble stalls theres about 15 selling a good selection of bits nos and second hand manuals ect autojumble queries phone anne on 01383 730234 thank you
  19. very nice john is it a bristol crawler ?
  20. we went to an commercial garage closing down sale and bought their large comp it powers the needle gun /sand blast cabinet /impact gun plus at the same time v twin pump single phase but very heavy
  21. hi every one thanks for response much appreciated the nos are model (252707) type (07120) code (89100931) hope that helps as theres nothing for it to sit in and theres no marks were somethings been thanks dave k the third photo is the set up apart from cable feeds from bottom
  22. aye but how i have a rod with a sort of s shape on carb end and on the other theres a large c shape but nothing to connect it to no holes or obvious bits is there something like a plastic clip missing ?
  23. hi everyone i now have the westwood running pretty good and starting off the key but theres a problem with a rod that comes off carb choke and goes behind ? the plate that the throttle is connected to but i cannot see where it belongs any suggestions it has to work in with the throttle throttle pulled full up is choke on shove it down and the choke goes off any help would be great many thanks dave k
  24. 1017 just as i was considering dropping a ton tattie box filled with tractor front weights then it got a repreive new clutch/new tyres x4/ new drive belt /newbattery /new exhaust / new seat cover / and sawbench thanks danarmdave
  25. yes it can take a bigger blade and you disconnect the drive belt and two chromed dome nuts and slip out bolts and you can lift off or reverse away from the frame i made up for that purpose or can just sit on blocks of wood as it is quite stable you just have to remember and not walk into angle arms sticking out as its v sore thank you danarmdave
