Martin H
    28
About Martin H
    Cambs
1,967 profile views
  1. OK, it's been a while, my C-125 gave up the ghost and has been sitting in the dry for quite some time. It had gear problems, needs a new exhaust and a thorough check over. Anyone willing to take it on and get it back to working order for a price? I don't have the skills or space to do it myself and my orchard desperately needs some attention.. Hoping for the best, Martin.
  2. Hi Stormin, An elementary question, how do I get in to inspect the plates to begin with? (As to the mule drive...it's the v shaped one that's gone. Not sure if they are pressed steel, I can't see any rivets. There may be small dents from spot welds, but hard to tell.. The wide one looks like it's made of two halves, but the v shaped looks like it's one piece. Anyway, I've taken your advice and tracked down a supplier and ordered a new wheel altogether, seems like the best thing to do as it's quite urgent that it gets replaced as soon as).. Thanks, M.
  3. Sorry, been away.. Thanks everyone, but I think this is beyond me and the capability of my workshop, I'll have to keep muddling through with the gears I have..:) Although I can select them eventually, the ones in high ratio lose power on small slopes, so maybe it's something else other than the fork? Could it be the drive belt? Anyway I have a worse problem in that the bearing has gone on one of the mule drive pulleys. Anyone have a solution? Maybe point me to a replacement bearing or pulley? Cheers, Martin
  4. Thanks Stormin, will do and my lips are sealed...:) And Meadowfield, yes stripping it would be my expectation. Getting the side plate off will be my first challenge..:)
  5. Hello all, I'm in need of some education and advice...:) My 125 is down to 2 gears in low gear and reverse, nothing in the higher ratios. Can anyone point me in the right direction for finding good information for sorting out the gearbox and transmission please ..? A good diagram as to how it all works would be a good start...:) Cheers, Martin H.
  6. Martin H
    Martin H
  7. Yep, the bar was the wrong way around, goes on easy peasy now... I thought it would be something obvious, don't know why the previous owner would have reversed it. Anyway it works now, all I have to do is get a belt that fits and I'm there.. Ordered one from belting online, but it's slightly too short. Ahem...or is there another knack to fitting a belt that I don't know about, beginning to feel like a dumbo here... Thanks all for the help, yet again...
  8. The right hand side of the deck/tractor if you're facing forwards..? I think this may be it...the fork is on the left.. For whatever reason, the previous owner had it that way round..I need to find my spanners... But it'll have to wait until I get back next week..
  9. Hang on a minute...which way should that fork be facing and angled and which side of the deck should it be nearest..?
  10. Right...seems like it's a knack....I shall give it another go and if I can't get it to work, I'll take some pics.. Yes the flat surface was the ground with a couple of boards to make sure it was flat... (Sorry my second post back there was an error, "This is a riddle", didn't realise we'd moved on to another page..)
  11. Thanks Stormin, now I know the fork does need to go around that bar.. Yes the raised pieces are inside the locking plates and I've got it on a flat surface square and lined up. It feels like the frame on top of the deck needs to move back a little so the fork can drop enough, but the right-angle pin holds it solid so there's no play. This is a riddle...
  12. Hi Stormin, Thanks, I thought that's where it goes. Yes,the raised pieces are inside the the edges, but I can't get the angle right so it will locate, the fork is angled too far back by about an inch. It looks like the cantilever frame on top of the deck needs to move back so the fork will drop a bit, but there's no adjustment to make it possible. That right angle pin in the middle of the frame holds it solid. Now I know where it's supposed to go, maybe it is something to do with where I've positioned the deck, but I've got it on a flat surface, square on, so it's at the right height. A weird thing for sure...I can see it should be easy to fit..
  13. Ok...been away for a while, so no progress with the belt, but I'm back on it now.. I have measured with a 1/2" rope as suggested and I got a size of 96" with the adjuster in a roughly middle position. So according to Anglo Traction's research it looks like it's probably the 102741 belt at 96.6", which I'll purchase from beltingonline.. I haven't found a local supplier yet, but it's a start.. I do have one more question if anybody's still reading this... The tach o matic system. When I try to attach the deck I find that the forked piece at the front of the deck on the cantilevered frame thing won't go around the bar above/inside the locking section. It's about a half inch out and there seems to be no room for adjustment to make it fit. The deck will go in without the fork being in position, but I'm not sure what the fork does and how important it is that it's seated around that small bar, if indeed that's where it's supposed to go.. Thanks again for all the info so far, absolutely invaluable... Cheers all.. Martin.
  14. Well A.Traction, that is thoroughly comprehensive, thank you. I have an agricultural engineering supplier near me, I was just going to take the old belt in and see if we could find a match, but this trove of information that you've supplied has thrown new light on the subject and will help even more. I suspect the belt I've got isn't the right one anyway, as when I fitted it I had to wind in the adjustment on the double pulley at the front nearly all the way in and that can't be right..(probably why the belt shredded after an hour or so.... I think the next step is the rope measurement, if I couple that with the section size, I might be able to find some kind of match at my local or use the link you gave me. That'll have to wait until next week. There's nothing on the spindle drive belt, so it's still a guess as to what model this is. Looks like it's going to be a problem finding out the model. I'll make some enquiries to the previous owner, see if I can get more details. This is almost as bad as finding a decent cutter deck in the first place... Thanks for the help and the link. I've now got some options.. Cheers, Martin.
  15. I knew it...! it's not that easy, I thought it was just me, but it is one of those subjects... Unfortunately the labels have worn off, so I don't know the model number, but it is definitely is a 42" side discharge. Mmmm..Kevlar or non Kevlar... Andy seems to have some good ideas, especially based on the direct experience of doing some heavy duty cutting. Which is what I'm approaching, this orchard is about an acre. And it looks like I'll be needing spares on hand. Kevlar just sounds tougher though.. One thing I've realised, the belts don't have to be brand specific, so that's a step forward. I do have the original belt, I say original, it came with the unusable deck so I don't know if it's the right one, it seems to be about the right length though, I'll check the profile tomorrow. So it's the 2 profile measurements and length/pitch I need to get right. The lists and numbers I find densely confusing, especially since I don't have a model number to start with. So I think I'll follow Andy and see if I can find someone who sells belts in my area. Thanks Wristpin and Andy, all that info was really helpful. Cheers, Martin
