Rayp 44 #1 Posted May 17, 2015 Iv 'e broken the top half of the handle to my Hayterette rough grass mower and wondered if anyone might have a replacement top handle,. Thanks. Share this post Link to post Share on other sites
Anglo Traction 998 #2 Posted May 18, 2015 Hello Ray, Can you post a picture of the Mower/broken part. I know of a possible source (1980 model) if it is not urgent. Share this post Link to post Share on other sites
Rayp 44 #3 Posted May 18, 2015 Hi Richard, Thanks for your reply. I have found a picture of a similar machine to mine and crudely added this above. The bottoms of the tubular handle have been compressed to semi-circular (to fit the bottom tubular handle) and have a threaded bar to go through the bottom handle and be tightened with a plastic knurled 'nut' Share this post Link to post Share on other sites
Anglo Traction 998 #4 Posted May 18, 2015 Ok Ray, I'm hoping to get down to check it out next week. I'll post pics here for you. I definitely remember that it has the same cast Ali Deck and Fern Green paint...all in good condition, except for the pullstart........... Just can't remember the Handlebar layout !. Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted May 18, 2015 Where abouts is it broken? Can an insert be made and the handle then welded up? Share this post Link to post Share on other sites
Rayp 44 #6 Posted May 20, 2015 Thanks for your help Richard. The handle is broken where the tube has been flattened and pressed into a semi circle to fit around the bottom round tube and probably could be welded (although I have no knowledge of welding!!). This will be the only option if I can't locate a replacement. Share this post Link to post Share on other sites
mowerdar 98 #7 Posted May 24, 2015 I have a handle of the type your looking for located never Glastonbury Somerset 1 Rayp reacted to this Share this post Link to post Share on other sites
Rayp 44 #8 Posted June 1, 2015 Hi and thanks for your response. How much do you want for the handle? Ray Share this post Link to post Share on other sites
