S1g 579 #1 Posted November 10, 2015 After looking for one of these early disc cutters for ages Ive finally purchased this one the other night off ebay. These were basically the early version of stihls infamous Ts 350, a machine that I used to do a lot with about 15 years, but even then these Ts 08's were just old junk. Today it arrived and after unpacking it I was able to see what I had bought. I believe it dates from around the mid to late 1960's. Share this post Link to post Share on other sites
S1g 579 #2 Posted November 10, 2015 The first thing with any project is to see what state its actually in. I learnt a long time ago with disc cutters because of all the stone dust the engines tend to be knackered. This one has proved to be no exception. The cylinder and piston are chewed up, the main berrings have gone, the clutch berring has also failed. Suprisingly enough though the crank feels ok. This would entail quite considerable expense, however as luck would have Stihl used the same engine unit in their 08s chainsaw and normally these tend to be good mechanically due to the saw dust being harmless to the engine. In my store ive got a broken one of these so hopefully I can have most of the bits off this doner. 1 sten reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted November 10, 2015 That's a bit of a mess. Share this post Link to post Share on other sites
S1g 579 #4 Posted November 11, 2015 On 11/10/2015 at 10:36 PM, Stormin said: That's a bit of a mess. Agreed, it does look rather bad. However this is pretty much par for the course with disc cutters due to the environment they are used in. Parts for the rebuild are allready on order, the only thing I haven't been able to source yet is the air filter cover, if no luck then as a tempory messure I will fit the one off the chainsaw. Share this post Link to post Share on other sites
S1g 579 #5 Posted November 12, 2015 Fortunatley gasket sets, berrings and seals etc are still available and quite cheap so I ordered them off ebay. I managed to get a close match to the paint from Halfords,and have now started the laborious task of removing the paint. Photos of this will have to wait as im struggling to get my I phone to talk to the pc. 1 nigel reacted to this Share this post Link to post Share on other sites
S1g 579 #6 Posted November 17, 2015 Made a bit of progress on this project today. Got the main parts primed and painted. After doing this I thought i'd better check out the chainsaw to see if it was savable. Fourtunatley it is good everywhere the disc cutter is bad so it will be full steam ahead with the rebuild. 1 nigel reacted to this Share this post Link to post Share on other sites
S1g 579 #7 Posted November 19, 2015 Now that the paint has had a couple of days to harden I have started to assemble this machine. Just waiting now for a few more parts to arrive then I should be able to have it running. 2 nigel and Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted November 19, 2015 Must admit, you do a grand job. 1 S1g reacted to this Share this post Link to post Share on other sites
S1g 579 #9 Posted November 19, 2015 On 11/19/2015 at 8:00 PM, Stormin said: Must admit, you do a grand job. Thanks for the compliment but there's nothing special about what I do. I just work methodically from one end to theother. The paint on this was all done with rattle cans, and the mechanical work was all done from memory. Share this post Link to post Share on other sites
nigel 1,880 #10 Posted November 20, 2015 luverly job once again 1 S1g reacted to this Share this post Link to post Share on other sites
S1g 579 #11 Posted November 20, 2015 One thing my machine was missing was the belt pulley guard. After a rummage through my store I tuned up this battered one. After a bit of panel beating and a coat of paint it was ok to refit. My diaphragm kit finally turned up tonight so I will fit it after the weekend. Share this post Link to post Share on other sites
S1g 579 #12 Posted November 27, 2015 The new badge has eventually turned up from the states, unfourtunatley I got hit for import duties etc which pushed the price up quite a bit. The second photo shows a sneak preview of my other project a 1960 Wacker Trench Rammer. Share this post Link to post Share on other sites
Stormin 4,458 #13 Posted November 27, 2015 Never heard of a trench rammer. Sounds interesting. Share this post Link to post Share on other sites
S1g 579 #14 Posted November 27, 2015 On 11/27/2015 at 7:55 PM, Stormin said: Never heard of a trench rammer. Sounds interesting. I'll take some more pictures when I get a bit further with it. They are basically used for compacting down back filled trenches etc. They can often be called by some politically incorrect names aswell ...This one was made in an era when health and safety was very lax so will tend to shake you to pieces when being used. Share this post Link to post Share on other sites
S1g 579 #15 Posted December 23, 2015 Finaly managed to get this saw finished today. Had to resort to a later spec air filter cover as I cant find an original type one anywhere at the moment. Started 3rd pull and after a bit of minor adjustment runs quite well. 1 Stormin reacted to this Share this post Link to post Share on other sites
S1g 579 #16 Posted December 24, 2015 A contact in the trade has just dropped me a line saying he thinks he may have the correct air filter cover in his store.fingers crossed. 1 nigel reacted to this Share this post Link to post Share on other sites
jimmyfloyd 0 #17 Posted December 5, 2017 I know this is an old topic, but I just got one of these and the disassembled pictures are very helpful. Still trying to decide if I am going to rebuild it or not. Share this post Link to post Share on other sites
S1g 579 #18 Posted December 15, 2017 On 12/5/2017 at 8:57 PM, jimmyfloyd said: I know this is an old topic, but I just got one of these and the disassembled pictures are very helpful. Still trying to decide if I am going to rebuild it or not. I'd say go for it, before they become extinct. All the bits are still available and cheap if you go for non genuine or purchase an old chainsaw. 1 nigel reacted to this Share this post Link to post Share on other sites
