jonnym 9 #1 Posted May 11, 2016 Hello I'm thinking of doing a light restoration to a couple of bits of equipment. I know sand strip prime/acid etch then spray is the best way to go, however a house renovation(stopping it from falling over) and a young family preclude spending so much time on it. Is there a paint which I can do a light rub down, degrease then spray or hand paint with out bare metal or primer. Is hammerite smooth the devils own paint or would it be OK. Its no where as good as it used to be before they got rid of the xylene. Just to note this is not on very old or valuable (historically or cost) things. Thanks Jonnym Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted May 11, 2016 Agricultural enamel covers quite well. Dries quite quickly as well. Tin or aerosol from an agriculture supplier. Share this post Link to post Share on other sites
jonnym 9 #3 Posted May 12, 2016 I had been looking at that and have used it before, but it has to go over primer. I'm guessing as I'm talking about bodging it, using it is as good bodge as anything. I think I will leave it as is and wait until I have time to do it properly. thanks for the help Jon Share this post Link to post Share on other sites
C-101plowerpower 548 #4 Posted May 12, 2016 usually scuffing up the paint is enought to get the paint to stick, might not be as proper as doing it from bare metal but it will work Share this post Link to post Share on other sites
