Cgoligher990 0 #1 Posted May 15, 2016 What would this wheel horse be worth not sure wat model it is Share this post Link to post Share on other sites
Cgoligher990 0 #2 Posted May 15, 2016 I'm lookin to buy it and I am not sure what to pay for it Share this post Link to post Share on other sites
the showman 4,074 #3 Posted May 15, 2016 Looks like a commando 7 or 8, but has the wrong engine ,no belt guard and the rear fender has been lifted up to clear the oversize tyres. has the bonnet been hacked about where the fuel tank filler is sticking out ? 1 Cgoligher990 reacted to this Share this post Link to post Share on other sites
Cgoligher990 0 #4 Posted May 15, 2016 I think the boy selling it has all the guards and stuff and I'm not sure if the bonnet has been hacked or not I'm not to familiar with these wheelhorse Share this post Link to post Share on other sites
DevonianRedneck 86 #5 Posted May 15, 2016 that engine looks way underpowered for it! 1 Cgoligher990 reacted to this Share this post Link to post Share on other sites
Cgoligher990 0 #6 Posted May 15, 2016 3 minutes ago, the showman said: Share this post Link to post Share on other sites
Cgoligher990 0 #7 Posted May 15, 2016 3 minutes ago, DevonianRedneck said: that engine looks way underpowered for it! It is he says it is an 8hp but it's something like a 3hp Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted May 15, 2016 It's a bit of a mess. What do you want to use it for? Share this post Link to post Share on other sites
DevonianRedneck 86 #9 Posted May 15, 2016 looks like it woundnt pull the skin off a bowl of custard to be honest! suprised it can turn the oversize wheels, it looks like a 2hp honda, plus because he's changed the engine it wont run pto attachments anymore, the bonnets been hacked for the fuel filler, andf the thottle levers been bodged , but these are just points to haggle the price down with, i've bought worse! 1 Cgoligher990 reacted to this Share this post Link to post Share on other sites
Cgoligher990 0 #10 Posted May 15, 2016 Just as a project to fix up And towin trees out with but I have an 8hp engine that I can throw in to it anyway Share this post Link to post Share on other sites
C-101plowerpower 548 #11 Posted May 15, 2016 How much is he asking? Share this post Link to post Share on other sites
meadowfield 1,900 #12 Posted May 16, 2016 Chris is right, either Commando 7/8 or maybe slightly earlier perhaps an 856 or summat... 1 Cgoligher990 reacted to this Share this post Link to post Share on other sites
Cgoligher990 0 #13 Posted May 16, 2016 He is wanting to swap my 1988 Honda trx 125 which is non working it needs two sprockets and a chain and the engine has a valve gone in it or something Share this post Link to post Share on other sites
Cgoligher990 0 #14 Posted May 16, 2016 1 hour ago, meadowfield said: Chris is right, either Commando 7/8 or maybe slightly earlier perhaps an 856 or summat... Would there be any modal numbers or tags on the frame I could check for ? Share this post Link to post Share on other sites
meadowfield 1,900 #15 Posted May 16, 2016 on early models its usually under the dash panel on the hoodstand, look at the steering column and then follow that line below the dash. Failing that either side of the alloy dash panel Share this post Link to post Share on other sites
meadowfield 1,900 #16 Posted May 16, 2016 on early models its usually under the dash panel on the hoodstand, look at the steering column and then follow that line below the dash. Failing that either side of the alloy dash panel 1 Cgoligher990 reacted to this Share this post Link to post Share on other sites
neil 524 #17 Posted May 17, 2016 I would say it's a commando 7 as it has a slot hitch , the 856 has 7 slat holes on the hood front instead of 6 & the light hole is solid on the 856 with just a decal & the steering wheel does not match a commando 8 so I thing it could be a 704 . i would say it's worth no more that £200tops if that to be honest in its current condition . Although it's a good tractor ,personally I would keep the Honda and get it repaired or wait for a better wheel horse to turn up Share this post Link to post Share on other sites
Cgoligher990 0 #18 Posted May 17, 2016 7 minutes ago, neil said: I would say it's a commando 7 as it has a slot hitch , the 856 has 7 slat holes on the hood front instead of 6 & the light hole is solid on the 856 with just a decal & the steering wheel does not match a commando 8 so I thing it could be a 704 . i would say it's worth no more that £200tops if that to be honest in its current condition . Although it's a good tractor ,personally I would keep the Honda and get it repaired or wait for a better wheel horse to turn up Well neil I was in need of a bigger ATV so i had bought a fourtrax 200 and I really abused the Honda 125 and I was lookin for another tractor anyway and I only paid £150 for the 125 so I think I'm doin alright and btw are many of yous from the UK Share this post Link to post Share on other sites
Cgoligher990 0 #19 Posted May 17, 2016 9 minutes ago, neil said: I would say it's a commando 7 as it has a slot hitch , the 856 has 7 slat holes on the hood front instead of 6 & the light hole is solid on the 856 with just a decal & the steering wheel does not match a commando 8 so I thing it could be a 704 . i would say it's worth no more that £200tops if that to be honest in its current condition . Although it's a good tractor ,personally I would keep the Honda and get it repaired or wait for a better wheel horse to turn up And thanks for the info the amount of knowledge in this forum is unbelievable!!! Share this post Link to post Share on other sites
