Keith 2 #1 Posted June 16, 2016 Hi Everyone, New to the forum, started playing cricket again late on in life and happlly got involved with the upkeep of the ground. Our Hayter Osprey shed one of its blades after hitting a hidden rock and tore through the edge of the cutting disc (No hole left). Hayter no longer do this part- any ideas where I could source one or do you think a feasible fix would be to drill new blade mounting holes (accurate spacing to attempt to keep some sort of balance) i.e move them all round a 20mm or so? Would an engineering shop be able to replicate the whole disc? Many thanks 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #2 Posted June 17, 2016 Best bet is to buy another non working Osprey for parts off eBay or Gumtree. You could put a Wanted ad on the MOM too. Share this post Link to post Share on other sites
Keith 2 #3 Posted June 17, 2016 Thanks very much for the reply, I'll post again if I find anything Share this post Link to post Share on other sites
Wristpin 399 #4 Posted June 18, 2016 (edited) Quite easy to produce a new disc as it was just a flat alloy sheet riveted to the hub but may be difficult to find somewhere using suitable alloy who will chop you off a bit rather than want to sell you a whole stock size sheet (8' x 4' ?) From memory each blade mounting point was reinforced with riveted on steel plate so has that been torn out as well? If so that would complicate the issue of moving each blade round a bit . Also am I right in thinking that it was not a completely circular disc but had flats between each blade? That would preclude moving the blades round 45 degrees. All adds to the attraction of finding a good used disc but, of course, they never come along when needed! Edited June 18, 2016 by Wristpin forum software put in an unwanted paragraph break! Share this post Link to post Share on other sites
Keith 2 #5 Posted June 21, 2016 Hi Thanks for the reply, luckily I have managed to source some spares off gumtree including one of these plates, its a bit of a schlep to go and get them (5 hour round trip) but what price rare bits eh? Many thanks Keith 1 Potash123 reacted to this Share this post Link to post Share on other sites
Potash123 26 #6 Posted June 24, 2016 Hi Keith. I recently restored one of those which went to a good home. I have another two in the green house. I would be keen to know how you get the old disc off of the shaft. Baited breath. Regards Colin PS There are loads of those discs about on ebay on a regular basis. Share this post Link to post Share on other sites
Wristpin 399 #7 Posted June 24, 2016 The disc is riveted to a steel flange which is part of the shaft - not listed separately so presumably a welded assembly. Share this post Link to post Share on other sites
Keith 2 #8 Posted June 24, 2016 Thanks! I'm about to go and look closely and hopefully I have the right one, is the shaft held in with a central nut/locknut, presumably on a shaft / woodruff key? Is any further dismantling necessary? Share this post Link to post Share on other sites
Wristpin 399 #9 Posted June 24, 2016 This may be of use https://www.dropbox.com/s/9pa2ow4nz4dixdn/Hayter Osprey and 21 0001.pdf?dl=0 Share this post Link to post Share on other sites
Keith 2 #10 Posted June 24, 2016 Thank you, that's fantastic. I actually went to the club earlier, the cutting discs I sourced were slightly smaller but using one of the pulleys that came with it managed to get it fitted and running tonight and cutting fine, just not as wide. At least it will buy us some time to get the original repaired or copied. 5 hour round trip to pick these bits up but the 2 spare gearboxes may come in handy as well as the other spare disc. Thanks for all the help Share this post Link to post Share on other sites
Keith 2 #11 Posted June 24, 2016 The original is riveted but also has 3 bolts which are covered by a cone shaped guard, luckily I didn't have to attempt taking the disc off the flange, just swapped them out Share this post Link to post Share on other sites
