Triumph66 1,256 #1 Posted April 23, 2017 At last I got around to sorting out the 600 which I bought from the States. Ohio to be precise. I replaced the fuel sediment bowl as it was missing the screw. I checked the plug and it was clean and turned it over and then it fired up happily. I let it ran for a wee while to warm it up. I then selected the gears. Nothing happened. Then I remembered I needed to put the cotter pin back in. I gave it a quick run in 1 and 2 and reverse. It was surprisingly nippy and managed to ride over the wood chips fairly easily. I decided to drain the transmission oil and engine oil which I duly did and replaced it with fresh oil suitable for the engine and the transmission. I gave it another run (in fact three runs) around the yard and track. I finally went into third gear and that was really nippy. I them decided enough was enough and put it into neutral and tried to engage another gear. Nothing happened at all. I looked at the belts which were slipping and noticed that one was off the pulleys. I managed to get it back on but still couldn't select a gear. The clutch pedal was down onto the floor and wouldn't come back up. I pushed it back to my storage marvelling at how quiet these 600 are.... i think a new new set of belts are in the cards. 2 the showman and Alan reacted to this Share this post Link to post Share on other sites
the showman 4,074 #2 Posted April 23, 2017 If your getting belts Andrew I'd be interested in some for mine . 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #3 Posted April 23, 2017 Chris I am buying mine from the US from Bolens Spares. $30 for a set. Share this post Link to post Share on other sites
Triumph66 1,256 #4 Posted April 23, 2017 (edited) Edited April 23, 2017 by Triumph66 1 Old Tankman reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #5 Posted April 23, 2017 Forgot to say that the video was created by Iain and his young son, Joseph. Share this post Link to post Share on other sites
