It's great to see another Hako on here. You've probably seen mine under step by step restoration?
At the present mind is set up with tines, but I've also got a set of guards and narrow blades like yours.
Titch has already worked his magic on decals for them.
Hi S1g  when I got it from down country everything was seized solid but with it not being common up North I thought it was worth a go. painting is in progress, everything is now free running, I left engine in diesel bath for 2 weeks before it freed off
If you get stuck for bits I have a very limited number of s/h spares for these machines as ive
broken an incomplete one up. I've also got a few more engine bits through my Wacker machines.
