H Killackey 6 #51 Posted January 15, 2021 (edited) I had a few Tanaka P7 Air Cleaner Covers made. I have listed them in eBay. They came out very good. They can be gentle sanded if you want to make them show quality. https://www.ebay.com/itm/164645598092?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Edited January 15, 2021 by H Killackey Share this post Link to post Share on other sites
E Killackey 0 #52 Posted April 20, 2021 HELP ! I need a FLOAT for my TAS P-7 Carburetor. We took apart the float bowl and look what we saw inside. I need help - Anybody? you can also contact at hkillackey@aol.com Share this post Link to post Share on other sites
CNew 404 #53 Posted April 20, 2021 Just a thought. The carburetors look similar to those used on some of the old Tanaka, Echo/Kioritz, and Shindaiwa engines. Maybe there is a float that is similar in size. For example, check out e-replacement parts or parts tree online and look up Echo PB-202. It has a similar float design and float bowl, maybe you’ll get lucky... Here’s a vintage Kioritz float - are the measurements close? https://www.ebay.com/itm/Vintage-NOS-Genuine-Echo-Kioritz-Float-P-120-133-0111-0/292981446733?hash=item44370e184d:g:Z-oAAOSwYyVcdEeD On 1/14/2021 at 8:31 PM, H Killackey said: I had a few Tanaka P7 Air Cleaner Covers made. I have listed them in eBay. They came out very good. They can be gentle sanded if you want to make them show quality. https://www.ebay.com/itm/164645598092?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Do you still have any of these? Share this post Link to post Share on other sites
E Killackey 0 #54 Posted April 21, 2021 THANKS for your help/Idea. I have ordered a Float from the link you suggested. I will let you know what happens. Share this post Link to post Share on other sites
Tom C 7 #55 Posted April 21, 2021 Hi I am in Australia, I have recently purchased some Tas P-7 engines, I am in need of a gearbox to build a mini bike, I would be interested to trade a good engine for a complete gearbox with clutch, please get in touch thanks regards Tom 1 factory reacted to this Share this post Link to post Share on other sites
factory 487 #56 Posted April 21, 2021 Nice find, they look a bit earlier than the P7 engine on the drill I have, unfortunately finding parts for these seems to be very difficult. Also nice to see some original literature with it too, I don't suppose it has any parts info or exploded diagrams in it that could help others? David Share this post Link to post Share on other sites
factory 487 #57 Posted May 6, 2021 There is a badly advertised & overpriced TAS pump on ePay in Canada, seller thinks it's an O&R, I did send them a message but they haven't replied or corrected it . https://www.ebay.com/itm/114666852338 Here are some pictures I have saved from the listing. David 1 pmackellow reacted to this Share this post Link to post Share on other sites
CNew 404 #58 Posted May 7, 2021 I’ve been watching that one as well and almost sent a message about the TAS motor but it’s priced so high I decided not to. It’s a cool pump but not at that price. Share this post Link to post Share on other sites
factory 487 #59 Posted May 7, 2021 I only sent a message to advise them it was not as described, they wouldn't want someone to claim for this when it arrives and is found not to be an O&R or Orline. No interest in buying at that price even if it had international shipping, same goes for the actual O&R powered tools he has. David 1 CNew reacted to this Share this post Link to post Share on other sites
H Killackey 6 #60 Posted September 12, 2021 (edited) HELP PLEASE - I need a Little Petro P-7 KEIHIN carburetor - OR a carburetor float. I have tried many other floats that do not fit in the KEIHIN float bowl. I have been looking for over 1 year now and I really need some help with this --- Help. I can also be reached at hkillackey@aol.com Edited September 12, 2021 by H Killackey Share this post Link to post Share on other sites
CNew 404 #61 Posted September 14, 2021 Can you add a photo of the float bowl? Would something like this maybe fit? https://www.ebay.com/itm/292981446733?hash=item44370e184d:g:Z-oAAOSwYyVcdEeD Share this post Link to post Share on other sites
H Killackey 6 #62 Posted September 16, 2021 (edited) My damaged float and the carburetor pics are about 5 posts above. Thanks for the eBay link for a float. I purchased it but the seller couldn't give me accurate dimensions. Maybe I will get lucky -- Edited September 16, 2021 by H Killackey Share this post Link to post Share on other sites
CNew 404 #63 Posted September 16, 2021 https://shopee.com.my/BRUSH-CUTTER-(BG328)-FLOAT-CARBURETOR-MESIN-RUMPUT-BG330-TB33-TL33-i.336498265.5164431335 this looks like a possibility too… try also searching parts for an Echo PB-202. It used a carb that looks very similar and the float is still available from PartsTree and eReplacement parts. Might be worth a try… https://www.partstree.com/models/pb-202-echo-handheld-blower-parts-sn-0001001-0040501/carburetor-3/ Share this post Link to post Share on other sites
Tom C 7 #64 Posted October 16, 2021 I posted a while back that I had bought a job lot of Tas P7 engines, I have found some things different between the early type and the later type. Early type : O.R type pull handle, roller guide for pull cord, starter cover screwed from the back, short intake manifold, serial numbers P7- 2xxxx Later type : Tas T pull handle, T Through pull cord guide, starter cover screwed from front, long intake manifold better balance factor crank, serial numbers I have P7- 4xxxx. Share this post Link to post Share on other sites
Tom C 7 #65 Posted October 16, 2021 Some engine parts from the Tas P7 owners handbook Here is a Tas P7 sheering machine. It’s missing the sheers and flexable cable, I believe they were standard to most machines. 1 CNew reacted to this Share this post Link to post Share on other sites
Tom C 7 #66 Posted October 16, 2021 I am still looking for a gearbox for a P7, and am happy to trade a good engine for one. Either a single reduction type P73 or a double reduction P74 is good thanks regards Tom Share this post Link to post Share on other sites
CNew 404 #67 Posted October 16, 2021 That Crutching unit is a nice find! I’ve never heard of such a thing. Thank you for posting all the manuals and parts info as well, this early TAS stuff is hard to find! 1 Tom C reacted to this Share this post Link to post Share on other sites
Tom C 7 #68 Posted October 16, 2021 2 hours ago, Tom C said: I am still looking for a gearbox for a P7, and am happy to trade a good engine for one. Either a single reduction type P73 or a double reduction P74 is good thanks regards Tom Share this post Link to post Share on other sites
Brandan Mayerhofer 1 #69 Posted December 28, 2021 I came across this and see that others collect…. Have extra parts also 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 404 #70 Posted December 28, 2021 Very nice, looks in great condition! What extra parts were you able to score? Share this post Link to post Share on other sites
H Killackey 6 #71 Posted December 28, 2021 Brandan It appears that your engine is a general purpose TAS motor with no gear reduction/transmission.. I see that on of the stickers on the cover says P-7 and the other says P-72. It also looks as if this engine rotates in the opposite direction of (2) TAS P-7's I have. I do not know if this motor could be used for a minibike. I state that because I use TAS P-7's for minibikes. Maybe you have seen pictures of my P-7 up in this string of posts. Are you interested in selling this motor and parts ? Share this post Link to post Share on other sites
Brandan Mayerhofer 1 #72 Posted December 28, 2021 Not sure what it was used for but it’s got a Throttle Yeah I don’t need it for anything That’s everything that was in the box with the motor…. Shoot me an offer Share this post Link to post Share on other sites
CNew 404 #73 Posted December 29, 2021 Cool- do you have plans for it or just a display engine? Share this post Link to post Share on other sites
Brandan Mayerhofer 1 #74 Posted December 29, 2021 No plans figured one of you guys might want it Share this post Link to post Share on other sites
Tom C 7 #75 Posted December 29, 2021 Brandon, the Tas P72 engine can be operated in different orientations, it is different to the other P7 engines in as far as it uses a diaphragm carb, some contraptions like the P7 generator also have engine speed governing with that carb too. from my owners handbook there appears to be 4 main versions of those engines that were sold. P7 = utility engine with regular carby. P72= utility engine with all position carby. Can also be fitted with a governor. P73=Utility engine with regular carby and single reduction gearbox. P74= utility engine with regular carby and double reduction gearbox. Like used on the little Petro. It looks a nice clean engine you have there, nice pickup. Share this post Link to post Share on other sites
