Triumph66 1,256 #51 Posted September 10, 2018 Scott, anymore updates on your 850? Share this post Link to post Share on other sites
Scottwilson 76 #52 Posted September 10, 2018 21 minutes ago, Triumph66 said: Scott, anymore updates on your 850? All of the new wires are here now for the new loom I just need to make it . Still had no luck with an ignition switch for it . 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Sammoore13bolens1053 11 #53 Posted September 10, 2018 Hi, mine was done with a on off switch for ignition, and a push switch to start. Would only start when the switch was on. I’m alright with wiring, and if your any good at wiring, you could do my setup Share this post Link to post Share on other sites
Scottwilson 76 #54 Posted September 10, 2018 5 minutes ago, Sammoore13bolens1053 said: Hi, mine was done with a on off switch for ignition, and a push switch to start. Would only start when the switch was on. I’m alright with wiring, and if your any good at wiring, you could do my setup I’m going to try to keep it as original looking as possible to start with . If not I’ll look at that set up . I’m useless with wiring . Making the looms not too bad as I have the old one to copy 😂 1 Sammoore13bolens1053 reacted to this Share this post Link to post Share on other sites
Sammoore13bolens1053 11 #55 Posted September 10, 2018 Just now, Scottwilson said: I’m going to try to keep it as original looking as possible to start with . If not I’ll look at that set up . I’m useless with wiring . Making the looms not too bad as I have the old one to copy 😂 Ahhh you can b that bad! Mine doesn’t look to bad. For a switch contact Brian, on bolenspartsandsupplies.com Share this post Link to post Share on other sites
