Scottwilson
1966 Bolens 850
5 minutes ago, Sammoore13bolens1053 said:
Hi, mine was done with a on off switch for ignition, and a push switch to start. Would only start when the switch was on. I’m alright with wiring, and if your any good at wiring, you could do my setup
I’m going to try to keep it as original looking as possible to start with . If not I’ll look at that set up . I’m useless with wiring . Making the looms not too bad as I have the old one to copy 😂
Ahhh you can b that bad! Mine doesn’t look to bad. For a switch contact Brian, on bolenspartsandsupplies.com
