howardman 30 #1 Posted November 28, 2019 Hi would anyone know where i could get a set of centrifugal clutch springs for a briggs engined 26" hayter roller drive. I damaged it a few months ago (hit a big stone in high grass) and it sent bits of the clutch flying ! anyway have done a repair but need 2 x clutch springs. They are a mighty machine to cut high grass. Share this post Link to post Share on other sites
Wristpin 399 #2 Posted November 29, 2019 If you have enough spring left to give length, coil diameter and wire diameter try Sprigmasters https://www.springmasters.com They are an excellent company but not really geared fo selling to Jo Public, heavy minimum order And carriage charges. However if you can identify suitable springs and then perhaps add a box of assorted for future use , it doesn’t look so bad. My Anzani Powermow is back up and running thanks to them. Worth talking to them, you might even be able to blag a couple of samples. Share this post Link to post Share on other sites
howardman 30 #3 Posted November 30, 2019 Thanks wristpin will give them a try . Share this post Link to post Share on other sites
