Charioux
Villiers engines
Hello my friends
 Can someone tell me what is the price, in England, of a new Villiers engine G390 (13hp)?
 Thank you
They are just a badged up Chinese copy of a Honda gx390., so you should be able to get one badged up as some Chinese name a lot cheaper. At my work we experimented with them quite a bit a few years back. The actual engines seemed ok, however the recoils are very weak and particuarly on the 200 range the governors were not allways that good, from the symptoms I would say that the washer underneath the governor was the wrong thickness.
If its a Chinese copy should it not be badged up as a Virriers ?? :D   (apologies to any Chinese MOM readers)
the new virriers engine, now at your local take away number 36. also would the box it comes in be microwave compatible?
Koen
