CNew 404 #1 Posted September 5, 2020 I was about to start going through this engine and thought I’d see if I could get some help first. It looks to be an early model but I can’t see the number until I remove it from the tank (could it be a “J”)? Unfortunately it’s missing the pull knob, which I assume would have been a brown knob (I only have a black one in my spares). I don’t know yet if the recoil spring is broken. It’s also missing the condenser. Anyone know what condenser is correct for these early ones? A picture or number stamped on the back of the condenser would be helpful. Looks to be missing the steel type engine cooling baffle as well but I think I might have one somewhere. Share this post Link to post Share on other sites
factory 487 #2 Posted September 5, 2020 That's one of the first 6000ish engines, it's possible it might not have a Model stamped into it, it's certainly not a Model J as it has the remains of the pump it was once part of. The capacitor would have been the slightly larger diameter one. The starter pull would have been the lacquered/varnished wood type, could you not try stripping the paint of a later one? David Share this post Link to post Share on other sites
CNew 404 #3 Posted September 5, 2020 Thanks for the photos! I’ve tried stripping the paint before but the black goes deep into the grain. I wasn’t Very successful at getting it to look good. I may try to make one. I wonder if a newer style condenser would work. I don’t have a you the ones like in your photo. I found a cooling baffle so that’s one part down... What would the rest of the pump have looked like? Share this post Link to post Share on other sites
factory 487 #4 Posted September 5, 2020 OK, do you know anyone with a wood turning lathe? Any condenser from an O&R would work, if an early style one had failed in service it would have been replaced with the later one. I've used modern parts too; The rest of the pump is the same as the Comet, Orline, Petro etc with the small rotary vane type pump, the type with the rubber impeller that always seems to be knackered. Petro version shown below; David 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 404 #5 Posted September 5, 2020 Very nice, is that one of your pumps? Those feet are interesting. Share this post Link to post Share on other sites
factory 487 #6 Posted September 5, 2020 Yes it's my Petro Chug-A-Pump, some more pictures of the wreck I started with in this thread; I really need to update that thread, too late tonight though. David Share this post Link to post Share on other sites
CNew 404 #7 Posted September 5, 2020 Wow, that’s quite the overhaul. It turned out really nice! I didn’t know Petro Powered Products made anything with O&R other than the really cool drill. Share this post Link to post Share on other sites
factory 487 #8 Posted September 5, 2020 I have the Petro drill, pump & chainsaw, probably won't find the mini-bike though, too expensive usually. David Share this post Link to post Share on other sites
CNew 404 #9 Posted September 5, 2020 I’m kicking myself to this day for missing a good opportunity on a drill. I forgot about the chainsaw those are really neat too. Share this post Link to post Share on other sites
CNew 404 #10 Posted September 5, 2020 Engine number is 005614 Share this post Link to post Share on other sites
factory 487 #11 Posted September 6, 2020 Here is another pump that your engine could have been part of, there is no branding on this one (if it had a decal it's long gone). The engine SN of this one is #005790. David 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 404 #12 Posted September 6, 2020 Interesting... thanks! By the way that primer button is different- never seen one like that. Share this post Link to post Share on other sites
CNew 404 #13 Posted September 7, 2020 I really like how these early models were designed. I’ve got it all torn down now. Share this post Link to post Share on other sites
factory 487 #14 Posted September 10, 2020 Looks in nice condition, hopefully it will be a straightforward rebuild, I still haven't got round to trying those new seals in my early engine, work keeps getting in the way. David Share this post Link to post Share on other sites
CNew 404 #15 Posted September 10, 2020 Overall it’s in pretty nice condition. I am going to need to come up with a solution for the induction case seal, it was deteriorated. Share this post Link to post Share on other sites
CNew 404 #16 Posted September 18, 2020 Finally all back together. I don’t have a natural wood knob so I have a black one on there temporarily. It has really strong compression now and spark but I haven’t tried to run it yet. 3 Daren89, pmackellow and factory reacted to this Share this post Link to post Share on other sites
factory 487 #17 Posted September 21, 2020 That looks in nice condition, looks barely used, you seem to be missing a screw for the cooling baffle. We need to find someone that can make a few replicas of the lacquered pull knob. David Share this post Link to post Share on other sites
CNew 404 #18 Posted September 22, 2020 19 hours ago, factory said: We need to find someone that can make a few replicas of the lacquered pull knob. Someone out there has a huge stash of these knobs from the recent eBay parts lots That sold. I’m trying to find someone local with a lathe to see what it would cost to turn a couple. If I had a lathe I’d do it... Share this post Link to post Share on other sites
factory 487 #19 Posted September 30, 2020 I tried & failed to win one of the lots with a couple of these in too, ended up risking buying a couple of the expensive NOS ones in black (with ePay's global shipping scrapping programme) that another seller had. David Share this post Link to post Share on other sites
CNew 404 #20 Posted October 1, 2020 I ended up doing the same thing. I’m still hoping to find someone locally with a lathe to make a couple. Share this post Link to post Share on other sites
alexandre69 0 #21 Posted October 11, 2024 Hi my name is alex from france. My friend is reparing same engine.ohlsson rice. Compact2 85hp .Could you help me to find condensator ref and high tension coil? If you know where to buy them on website will be Wonderfull. Thanks in advance Share this post Link to post Share on other sites
