I am looking for a condensor carb rebuild kit or a complete carborator for a Tiny Tiger generator model 62 I think or 67 I can't read the second number, all help is appreciated.
I was told either Wallfish or Webhead may be able to help, I am not sure if this is how to reach them?
Edited by LEY
:WMOM:
Replacement carbs are hard to find, is there a reason why it can't be rebuilt with a new diaphragm?
Is the condenser missing or have you tested it and found it's faulty? I have fitted modern film types when they are no good.
The model could be either 65 or 67, the Tiny Tiger with the larger gas tank is a Model 67 and the smaller gas tank is a Model 65. They used other model numbers as well.
@CNew or @Wallfish should be able to help with a new diaphragm for the carb if you are in the US, send them a private message using the little envelope symbol at the top right of the webpage (it's in the menu if you are using a mobile device).
David
