CNew 408 #126 Posted December 18, 2022 Yes, I’m not good at linking pages on here but if you go to the main Ohlsson Rice page there is a section title Brochures, etc that has parts list and other info. I looked up that part number and it looks like it’s the Roller Retainer for the later 13B engine. Go to this page and pull up the info on the 1970s engine. 1 tvenetis reacted to this Share this post Link to post Share on other sites
Wallfish 717 #127 Posted December 20, 2022 On 12/18/2022 at 1:29 PM, tvenetis said: Is there a parts list with numbers I can get for the ohlsson tinuy tiger and other compack engines?I found a o & r seal PN 400310 someone had is that a crank shaft seal? There's a whole section on manuals here in the manual section for IPLs Ohlsson & Rice Compact Operation Instructions May 62 Parts List 9-1-62 Service Directory May 62-1.pdf 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #128 Posted December 22, 2022 On the exhaust I put the rubber gaskets on like you said with the curve part toward the exhaust manifold then there is a bigger metal ring and I put it on the cylinder with the curve down to match the gasket then do you put the 2 smaller metal ring gaskets on then the o ring? Share this post Link to post Share on other sites
tvenetis 1 #129 Posted December 23, 2022 (edited) I get my water pump running but when I shut it off gas is going in to the carburetor. I put new diaphragm in it also. I noticed that the ball is not stopping the fuel so I have to try to figure it out a friend put it together wrong. Edited December 23, 2022 by tvenetis Share this post Link to post Share on other sites
Wallfish 717 #130 Posted December 24, 2022 On 12/22/2022 at 5:03 PM, tvenetis said: On the exhaust I put the rubber gaskets on like you said with the curve part toward the exhaust manifold then there is a bigger metal ring and I put it on the cylinder with the curve down to match the gasket then do you put the 2 smaller metal ring gaskets on then the o ring? All of those metal rings go on after the gaskets. The last thing to go on is the O ring which seals the connection of the case and the head. The rest seals the manifold and the head On 12/22/2022 at 10:24 PM, tvenetis said: I get my water pump running but when I shut it off gas is going in to the carburetor. I put new diaphragm in it also. I noticed that the ball is not stopping the fuel so I have to try to figure it out a friend put it together wrong. Yup, that check valve bearing should stop gas flow. Something is wrong 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #131 Posted December 29, 2022 I am putting together a chicken power recoil. I have the spring in and I put the rope threw the hole in the spool and tie a small knot in it on the side the spring goes on the spool. I put a roune piece looks like cardboard on the spool and I fix it so the knot lies on top of the round paper piece but when I put everything in the housing the recoil rubbs but if I remove the paper piece it works find. What am I missing thanks. Share this post Link to post Share on other sites
CNew 408 #132 Posted December 29, 2022 Can you add a photo? Is the engine a 13A or 13B? Share this post Link to post Share on other sites
tvenetis 1 #133 Posted December 29, 2022 I will try to get a photo tomorro. The recoil is square and bolts on to the housing with 4 screws. It says 1973 on the engine. Share this post Link to post Share on other sites
CNew 408 #134 Posted December 29, 2022 That’s the 13B. I think there is supposed to be a thin plastic disc (as opposed to paper) that the recoil slides on. I’ll have to see if I have an old unit that is open and can take a look. If I recall it’s just thin plastic, might be able to cut one out of a piece of disposable Tupperware, milk carton, or some other packaging. Share this post Link to post Share on other sites
tvenetis 1 #135 Posted December 29, 2022 (edited) It is a thin piece probably made of plastic. It seems like the knot that comes out of the hole on the spring side of the spool rubbs on the spring. How would you prevent that. Edited December 29, 2022 by tvenetis Share this post Link to post Share on other sites
tvenetis 1 #136 Posted December 30, 2022 I left the thin plastic off and I found a spring with less coils and now it retracts okay. On another engine I was replacing the crank and when I went to unscrew the cylinder the connecting rod broke and I was able to tap the piston out of the cylinder without damage. How do you remove the clips that hold the wrist pin to the piston. Share this post Link to post Share on other sites
CNew 408 #137 Posted December 30, 2022 I just busted a crank on a seized engine. There should be a little c-clip on one side, remove that and you should be able to tap the wrist pin from the opposite side. 1 tvenetis reacted to this Share this post Link to post Share on other sites
tvenetis 1 #138 Posted December 30, 2022 (edited) I just found out there is different sizes of connecting rod where it fits on to the crank and different sizes of crank. Does any one know what part number rod I need for the 13b engine, I found a crank part. Edited December 30, 2022 by tvenetis Share this post Link to post Share on other sites
tvenetis 1 #139 Posted December 31, 2022 I am putting the crankshaft flywheel side in a 13 b engine but it is hard to pack the needle bearings in the block because there is a overhang piece just over where the bearings sit so do you put the bearings on the crank then drop it in the block? Share this post Link to post Share on other sites
tvenetis 1 #140 Posted December 31, 2022 I am trying to put the bearings on the crank shaft but the grease does not allow them to stick on it. Share this post Link to post Share on other sites
CNew 408 #141 Posted December 31, 2022 I always pack the roller bearings into the inner race of the connecting rod (with wheel bearing grease which is stickier), then I gently slide the connecting rod over the crank shaft being careful not to hit the overhang as I maneuver it onto the shaft. Works like a charm… Share this post Link to post Share on other sites
tvenetis 1 #142 Posted December 31, 2022 (edited) Thanks but I am referring to the crankshaft bearings that go in to the bottom half of the engine. You can't pack the bearings in the engine first because there is a part in the block that flares out above where the bearings would fit in the block. it looks like a washer to prevent the bearings from moving. I have a picture of what I am talking about I took a bolt and wedged the head against what I thought was a washer and tapped it out. It was the outer race of the bearing. I have to try and repack it with the needle bearings and put it on the crank and carefully drive it in the hole again. Edited January 1, 2023 by tvenetis Share this post Link to post Share on other sites
tvenetis 1 #145 Posted January 2, 2023 I am going to put the piston on the connecting rod but how do they pack those small bearings on to the connecting rod? Share this post Link to post Share on other sites
tvenetis 1 #146 Posted January 8, 2023 (edited) some one helped me pack small bearings so now I am reassembling the chichken power gearbox. There is a small gear that goes on the stepped shaft but I am not sure what that does because it does not contack any other gear it is raised up before you put the top cover on thanks. I found out that was not a gear but bearings went in the notches of that piece. Edited January 9, 2023 by tvenetis Share this post Link to post Share on other sites
tvenetis 1 #147 Posted January 10, 2023 (edited) I am putting a new rope on a chicken power recoil 13 b engine and I put the knot on the spool comming out the flywheel side and it rubbs when I tighten the recoil. If I put it on the spring side it interferes with the spring. Edited January 10, 2023 by tvenetis Share this post Link to post Share on other sites
CNew 408 #148 Posted January 11, 2023 It’s been awhile since I messed with a 13B recoil. If I recall it’s similar to, or the same, as the larger 20A engine. The knot goes through the inside of the spool hub. Take a look at the manual linked below, there are some good photos of the recoil. Share this post Link to post Share on other sites
tvenetis 1 #149 Posted January 11, 2023 On the chicken power 13 b the nipple on the carb is loose. Is there a way to fix that or can some one tell me the number of the piece I have to find. I can't read the manual thanks. Share this post Link to post Share on other sites
tvenetis 1 #150 Posted January 12, 2023 I remember from the other ohlsson forum they were talking about using another carburetor but I did not follow up on it. Does any one know anything about that? Share this post Link to post Share on other sites
