tvenetis 1 #1 Posted October 5, 2022 I am repairing a recoil for a ohlsson drill and was wondering how to wind the spring. I made a 2 inch pipe to fit the spring in after it is wound thanks. Share this post Link to post Share on other sites
Wallfish 717 #2 Posted October 5, 2022 I do them by hand. Get most of it wound into a coil then pinch the coil with your fingers. To tighten and shrink the coil size, pull on the loose end while pinching the center tight and it will tighten up. Hold it the whole thing tight and wrap 5-10 more wraps around and pull it again. Repeat the process until it's small enough and all coiled up. It takes a little while It's easier if it's clean and dry. Oil it after it's installed into the housing Let me know if this doesn't make sense Share this post Link to post Share on other sites
tvenetis 1 #3 Posted October 6, 2022 Thanks I tried that but it is hard to hold the center from uncoiling. Share this post Link to post Share on other sites
tvenetis 1 #4 Posted October 6, 2022 I finally got it wound. I took small vice grips and I held the spring near where it fits on to the spool. Then I held the vice grips in a vice and wound the spring then I took another small vice grips and squezed the spring so it would not unwind. I took the middle vice grips off and dropped the spring in the housing. Share this post Link to post Share on other sites
Wristpin 400 #5 Posted October 7, 2022 It’s a horrid job needing strong fingers. Just stripped and rebuilt a couple of Siba starters on Villiers F12s. Strong old springs. Nearly there and it jumps out and wraps around your arm like a demented snake ! Villiers own starter on the same engine jus winds in from outside. Why can’t they all be like that? Share this post Link to post Share on other sites
tvenetis 1 #6 Posted October 13, 2022 Since I can't see pictures is there text on how to wire the rope on the spool? Share this post Link to post Share on other sites
