Stormin
Kohler exhaust valve
   I need an exhaust valve for a Kohler K301as 12hp engine. Tried L&S Engineering without success. Anyone got a scrap engine they could take one out, or ideas as to where I can obtain one.
Hi, Stormin. I was going to suggest that you try Mike Hitchins at Guy Parts and Service but I’ve since discovered that all the various links to his web addresses appear to be broken . Can only assume that he’s no longer in business.
Edit. Just been informed that the company has been dissolved .
Edited by Wristpin
Checked my stock, only have a good Inlet Valve left. Must've pased the exhaust one on?.
Another suggestion is to grind down an inlet to the exh spec. I presume you still have the old one?. Would need to be done by a good engineering shop person though!.
