UnicycleParrot 2 #1 Posted July 8, 2024 (edited) Hello everyone. I have experience in small engine repair (mainly 4 stroke) on engines no older than 15 years old. I know how 2 stroke engines work too. I have recently obtained an old O&R engine, which seems to be in great shape. I do not know what the engine originally came off of, it also has no markings on it with a model number (or any number for that matter). One question I have is about the carburetor. Every carburetor picture I have seen on this forum has a red primer button, and a slotted jet on the top. Mine, however, has no primer button or a slotted adjustable jet on the top. Instead, there is a non-slotted knurled screw. I am also confused, because my unit does not seem to have any off switch, to stop the spark. Additionally, I am curious as to what the single point is for on an engine like this is for. On all the modern engines that I have worked on, there are no points. I have attached some pictures too for you to look at. By the way, I have not attempted to start it yet, as I am somewhat unsure of what fuel ratio it needs. Edited July 10, 2024 by UnicycleParrot 1 CNew reacted to this Share this post Link to post Share on other sites
Wallfish 701 #2 Posted July 9, 2024 What you have is one of the early engines. Wood tone handle instead of black, early coil, the blower housing screws are from the back instead of the heads on the front, no primer carb, jet screw on the side instead of the top, etc etc. All of those are normal things for an early type engine. There should be a hole in the bump on the top of the blower housing which holds a metal tab to ground the spark plug off to stop it. I'm not sure what you mean by it having a "single point". The points are under the flywheel and under that little cover that will be exposed after the flywheel is off. There are 2 point contacts that touch one another and probably need to be cleaned because they oxidize over time and that will prevent continuity because they aren't actually touching together. You can mix modern 2 stroke oil at 32:1 If the diaphragm in the carb is stiff it will need to be replaced in order for it to pump fuel. Share this post Link to post Share on other sites
CNew 407 #3 Posted July 10, 2024 Very nice engine, looks to be in great condition. Might want to put some liquid electrical tape or heat shrink over the spark plug wire😁 Share this post Link to post Share on other sites
UnicycleParrot 2 #4 Posted July 10, 2024 Thank you for such a timely and and helpful response! 5 hours ago, Wallfish said: What you have is one of the early engines. Wood tone handle instead of black, early coil, the blower housing screws are from the back instead of the heads on the front, no primer carb, jet screw on the side instead of the top, etc etc. All of those are normal things for an early type engine. There should be a hole in the bump on the top of the blower housing which holds a metal tab to ground the spark plug off to stop it. I'm not sure what you mean by it having a "single point". The points are under the flywheel and under that little cover that will be exposed after the flywheel is off. There are 2 point contacts that touch one another and probably need to be cleaned because they oxidize over time and that will prevent continuity because they aren't actually touching together. You can mix modern 2 stroke oil at 32:1 If the diaphragm in the carb is stiff it will need to be replaced in order for it to pump fuel. I do have the kill-switch piece of metal that is supposed to screw onto the top of the blower housing. I took it off when I first got the engine, because I figured it was some random thing that was on there from the previous owner. I have absolutely no experience with engines of this vintage (2 or 4 stroke) I know a few things about its life. The previous owner I never saw in person, but I hear he never used this engine. I also heard that long ago he was planning to make a minibike out of this engine. (kind of like the one you made @Wallfish) The engine has also been indoors for many years of its life (obviously) When I said "a single point" I figured it would maybe be called that because there is only one cylinder (thus only 1 set of points) I looked at the points when I first got the engine, and they are very clean. (like the rest of the engine) I also checked if it has spark, which it does. It is interesting to hear that it is an earlier model. I am a little curious if it is in better condition than others of the same vintage. 32 minutes ago, CNew said: Very nice engine, looks to be in great condition. Might want to put some liquid electrical tape or heat shrink over the spark plug wire😁 Yes, deffinitely! Share this post Link to post Share on other sites
Wallfish 701 #5 Posted July 10, 2024 19 minutes ago, UnicycleParrot said: It is interesting to hear that it is an earlier model. I am a little curious if it is in better condition than others of the same vintage. Yes, it's in very nice condition. I have 2 of those Share this post Link to post Share on other sites
UnicycleParrot 2 #6 Posted July 10, 2024 (edited) Interesting. Mine doesn't even have the oil hole for the pull starter. Just edited the first post for better pictures Edited July 10, 2024 by UnicycleParrot Share this post Link to post Share on other sites
CNew 407 #7 Posted July 11, 2024 I have 2 engines like this as well. One has the oil hole and the other doesn’t. Share this post Link to post Share on other sites
UnicycleParrot 2 #8 Posted July 12, 2024 It runs! I mixed up roughly 32:1 of fuel and 2 stroke oil and attempted to start it. At first the fuel mixture screw was way too rich (lots of fuel out of muffler), but I got it dialed in and I got a handful of 1/2 to roughly 1 second runs. Once it finally sounded like it was about to run, the spark plug wire fell off. I have a few other questions about the engine though. While I was taking apart the carburetor to check the diaphragm a little while ago, I noticed a small pinhole in the top of the carburetor. I assume this is not supposed to be there. I have repaired a hole in a carburetor on a 4-stroke engine with a 2-part aircraft epoxy. Would that work in this situation too? And about the spark plug wire (and the other wires connected to the magneto) is there anything I need to be careful about or worry about when soldering new wires in their place? Is there any type of a runaway scenario possible on an engine like this one? (imagining we had no way to kill the spark) Could the engine keep going full throttle and blow itself up? Share this post Link to post Share on other sites
CNew 407 #9 Posted July 13, 2024 That’s awesome, glad to hear you got it running. I’m pretty sure that hole in the top of the carburetor is supposed to be there, I think it allows the diaphragm to pulse. I’ll take a look at mine and see if it has the hole. can you add a photo of there you plan to solder wires? Share this post Link to post Share on other sites
UnicycleParrot 2 #10 Posted July 13, 2024 (edited) I figured that I would cut around here, leaving a section to solder a new wire to. On the other end, I want to save the little C shaped piece to solder onto the new wire, so I plan to cut it off and solder it to the new wire. Also, what are the NOS engines that I have heard about and seen pictures on this forum. Are they bigger in some way? Or are they newer? Edited July 13, 2024 by UnicycleParrot Share this post Link to post Share on other sites
CNew 407 #11 Posted July 13, 2024 I think I’ve had to do that same fix before as well. I don’t recall any issues with adding a new wire spliced in right about where you’re pointing. If the wire core isn’t really damaged you might also be able to just break off all the old insulation and then do a couple layers of shrink tubing. You’d still have to remove and reattach the little clip. i can also confirm, my carb also has the little hole. Share this post Link to post Share on other sites
Wallfish 701 #12 Posted July 13, 2024 Yes the carb cap hole should be there. The abbreviation NOS = New Old Stock I've repaired those cracked insulation wires. Removed the cracked insulation, coated with liquid electrical tape (a few coats), covered with shrink tube. It can be covered with different sizes of shrink tube over top of each other but it makes it kind of stiff Yes, any engine can "run away" with high RPM. Share this post Link to post Share on other sites
UnicycleParrot 2 #13 Posted July 18, 2024 (edited) Thanks for the advice! On 7/13/2024 at 3:07 PM, Wallfish said: I've repaired those cracked insulation wires. Removed the cracked insulation, coated with liquid electrical tape (a few coats), covered with shrink tube. It can be covered with different sizes of shrink tube over top of each other but it makes it kind of stiff Is there any specific reason on why you would suggest a repair of the spark plug wire, and not just a complete replacement? Also, is there a specific gauge of wire that is best for a spark plug wire? Edited July 18, 2024 by UnicycleParrot Share this post Link to post Share on other sites
Wallfish 701 #14 Posted July 18, 2024 5 hours ago, UnicycleParrot said: Thanks for the advice! Is there any specific reason on why you would suggest a repair of the spark plug wire, and not just a complete replacement? Also, is there a specific gauge of wire that is best for a spark plug wire? Yes, those older type coils are not a replaceable wire like the newer type coils are. You can repair it with a new wire but you're still soldering and repairing the insulation anyway. By just repairing/replacing the insulation on the old wire, it remains looking original. Plus, I don't know of any plug wire to repair it with. Share this post Link to post Share on other sites
UnicycleParrot 2 #15 Posted October 1, 2024 (edited) I'm back!!! I have had a busy summer, and i am finally getting around to posting this. I have replaced the crusty old spark plug insulation (2 layers of shrink tubing) Also, I had problems with fuel system, so I properly modified it. (maybe epoxy isn't proper I guess) Also, because I have access to a mill, I can make a compex shape for a motor mount. I also have one question. Is the air vane governor guaranteed to work? I say this because I had it running today, and it sounded like it was trying to go pretty fast (maybe hitting 2000rpm) Now, I know that these engines can hit around 5000rpm idle, I just didn't have my tach hooked up at the moment, and I didn't want to risk any damage. Can I just start it up and then walk away expecting the governor to work first time without any tweaking? Also, should my carburetor diaphragm be kind-of wrinkly? I believe it is the original diaphragm and it has not been replaced. Thanks Edited October 1, 2024 by UnicycleParrot 1 Wallfish reacted to this Share this post Link to post Share on other sites
Wallfish 701 #16 Posted October 2, 2024 RPM at full throttle is 6300 So yeah, they scream a little bit Governor is never "guaranteed" but they seem to work very well. I've never had one fail while the engine is running. It's controlled by the spring on the bottom of the carb. No adjustments are available on those older versions. Newer ones have a lever that can adjust tension on the spring Diaphragm should be soft and pliable for best results. Wrinkles indicate it's probably old and stiff. 1 UnicycleParrot reacted to this Share this post Link to post Share on other sites
tvenetis 0 #17 Posted Saturday at 03:21 PM I modified the muffler pipe on a tiger tiger and screwed a briggs stratton small muffler but it is still noisey. Is there a quieter muffler I can adapt thanks. Share this post Link to post Share on other sites
Wallfish 701 #18 Posted Monday at 09:52 PM On 10/4/2025 at 11:21 AM, tvenetis said: I modified the muffler pipe on a tiger tiger and screwed a briggs stratton small muffler but it is still noisey. Is there a quieter muffler I can adapt thanks. The Tiny Tiger model 350 used a different style muffler. Or search on epay for 2 stroke muffler and maybe adapt one. Share this post Link to post Share on other sites
tvenetis 0 #19 Posted Tuesday at 01:33 AM I had original muffler on it stil very loud so I will look for another. Share this post Link to post Share on other sites
Wallfish 701 #20 Posted Tuesday at 02:00 AM 22 minutes ago, tvenetis said: I had original muffler on it stil very loud so I will look for another. Yours is a model 350? Like pictured above? That style is quieter than a 300 is. The 300 just used the common little black mufflers/spark arrester. Are you using that for camping or something? Like the outboards do, if you run a metal hose from it into a bucket of water all you will hear is water bubbling so maybe you could experiment with that???? Share this post Link to post Share on other sites
tvenetis 0 #21 Posted Tuesday at 02:38 AM It took the small muffler and I am just running it not for camping. I am going to try and run a battery charger with it. Share this post Link to post Share on other sites
Wallfish 701 #22 Posted 4 hours ago On 10/6/2025 at 10:38 PM, tvenetis said: It took the small muffler and I am just running it not for camping. I am going to try and run a battery charger with it. The 2 small posts are already 12v DC. They were mostly used to run the 12v electric starters for RC stuff but it should also work to charge 12v batteries as well. Manual here file:///C:/Users/urema/OneDrive/Desktop/Tiny%20Tiger%20Generator%20Operating%20Instructions%20Models%205001-1%20&%205001-2.pdf Those small mufflers can be stacked but finding them at a reasonable cost may be difficult. Lots go missing because people take them off and don't put them back so everyone is always looking for mufflers and air cleaners. Share this post Link to post Share on other sites
tvenetis 0 #23 Posted 45 minutes ago I clicked on the manual and it said can't access it. Share this post Link to post Share on other sites
