Mitch 1 #1 Posted February 27, 2025 Hello everyone, I am new to the forum and looking forward to have fun restoring my Tiny Tiger Generator. The first thing I did was to degrease it and found that I am missing the carburetor jet. I was wondering if I could purchase that and a kit for the carburetor. Or if anyone knows where I could purchase a carb. Share this post Link to post Share on other sites
Wallfish 719 #2 Posted February 28, 2025 Are you referring to the actual needle valve? Some of the older engines had a smaller needle valve on the side of the carb and a screw which holds the diaphragm assembly to the lower carb body. Newer models have the the needle holding the diaphragm assembly to the carb body. Maybe a pic would help determine what carb you have and what you're missing. Share this post Link to post Share on other sites
Mitch 1 #3 Posted February 28, 2025 Here's some pics. Share this post Link to post Share on other sites
Wallfish 719 #4 Posted February 28, 2025 You need the gasket, the plastic check valve, the complete needle valve. Probably a diaphragm Have you opened up the cover to see if any other parts are missing in there? Arm, spring, bearing ball? I'll take a look around to see if I have a complete valve, Share this post Link to post Share on other sites
Mitch 1 #5 Posted March 2, 2025 Hello Wallfish, Any luck finding a needle valve assembly. Share this post Link to post Share on other sites
Wallfish 719 #6 Posted March 2, 2025 7 hours ago, Mitch said: Hello Wallfish, Any luck finding a needle valve assembly. Found a housing and a needle ( #21, 25 ) but not the little parts, washer, o ring or spring ( 22, 23, 24 ). You can get those at any good hardware store or find something online Did you ever open the carb to make sure the other parts are there? Someone lost the valve so you should check EVERYTHING to make sure you don't need anything else. You can do everything else on your engine like cleaning the points if it doesn't have spark now, fix the recoil (DO NOT DRILL OUT THE RIVET), etc etc. Fire it up with a squirt of 32:1 mixed fuel to verify it's a running engine. And you can also check the generator when it fires off too. If it doesn't run or generate power, does taking my last valve make sense? Your welcome to it if you need it! Share this post Link to post Share on other sites
CNew 408 #7 Posted March 3, 2025 Sorry I’m late to the party, was on business travel. I’ll take a look around my parts as well to see if I have any of the pieces. FYI- in case you do need all the gaskets and plastic reed valve: https://www.ebay.com/itm/114847057767?_skw=ohlsson+rice+carburetor&itmmeta=01JNE803DJR4Q3T4XPX1KT1QZM&hash=item1abd6b0767:g:1zoAAOSwIGhgOwOk&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1dQEOAC8QS1PfgADOOmUESYpF9BxHQioV10rfLg2aaBMCzLA51Tto4yDb6lZYdpJhMkxTynFCveVe3jM%2BM61xpIQn%2FfX1t26oOyYpH2nQZUGf0Zu5x38Yso4pXGrt7OK7ftKvO9WvzqDNyEdfpzcoi6x8eea9aS9Mo3BAHG0Ml4qwsWfOS18mifIP2xeZTK6L2pHMrGpsij1qn2%2FBsOA%2F8ZKJy2sOHz8uaPJrepLkZoEZVc92prp8RrZUl0gR7uKmlPcZbjZ96UFg76N8Vvlud--BPd8VTF%2FGc2036oAcN4LQ%3D%3D|tkp%3ABk9SR4S3gMirZQ Share this post Link to post Share on other sites
Mitch 1 #8 Posted March 3, 2025 (edited) I repaired the recoil, cleaned and gapped the points, repaired the spark plug wire and put a little gas in the carb and it fired right up. I forgot to plug in a drop light but I will tomorrow as I ran out of time. I will need a diaphragm carb kit, its stiff and dried out. B ut all the parts are there. Except of course the main jet.I don't think I need a reed valve. Edited March 3, 2025 by Mitch 1 Wallfish reacted to this Share this post Link to post Share on other sites
Wallfish 719 #9 Posted March 4, 2025 Nice, let me know if you need that one I PMed you about. I have diaphragms too. Share this post Link to post Share on other sites
tvenetis 1 #10 Posted October 10, 2025 I have a needle valve spring and the nut that screws in to the carburetor. Share this post Link to post Share on other sites
Mitch 1 #11 Posted October 10, 2025 I need the whole needle valve. I have found its not worth what the cost is and I put it on the shelf, If you would like to buy it give me an offer. Share this post Link to post Share on other sites
tvenetis 1 #12 Posted October 10, 2025 you need the needle valve and what else. Share this post Link to post Share on other sites
Mitch 1 #13 Posted October 10, 2025 and the diaphragm kit. Share this post Link to post Share on other sites
tvenetis 1 #14 Posted October 10, 2025 I think I have a diaphram and gasket if interested. Share this post Link to post Share on other sites
tvenetis 1 #15 Posted October 11, 2025 I have the needle valve and diaphram and gasket if interested. Share this post Link to post Share on other sites
Mitch 1 #16 Posted October 11, 2025 How much are you looking for? Share this post Link to post Share on other sites
tvenetis 1 #17 Posted October 11, 2025 25.00 plus shipping Share this post Link to post Share on other sites
Mitch 1 #18 Posted October 11, 2025 How much is the shipping, I'm in Ma. 02645 Share this post Link to post Share on other sites
tvenetis 1 #19 Posted October 11, 2025 I will put it in a padded package probably 5.00. What else do you need Share this post Link to post Share on other sites
Mitch 1 #20 Posted October 11, 2025 That is all I need, how would I pay you? Share this post Link to post Share on other sites
tvenetis 1 #21 Posted October 11, 2025 do you have paypal? and we can talk here is my email tvenetis@optonline.net Share this post Link to post Share on other sites
Mitch 1 #22 Posted October 11, 2025 I don't have PayPal. Share this post Link to post Share on other sites
tvenetis 1 #23 Posted October 11, 2025 you can send me by mail Tim Venetis 1369 RT 55 Lagrangeville New York 12540 I packed it all up. Share this post Link to post Share on other sites
Mitch 1 #24 Posted October 11, 2025 would you be interested in buying it? Share this post Link to post Share on other sites
tvenetis 1 #25 Posted October 11, 2025 No thank you Share this post Link to post Share on other sites
