Potash123
    171
Potash123 last won the day on November 9 2018
Potash123 had the most liked content!
About Potash123
    Essex
    Motorcycle restorations.
5,070 profile views
  1. What threads are used on the model please, thank you.
  2. Good plug, Cleaned the coil and set air gap. No sign of a spark. The dead mans handle appears to be doing its job according to my Fluke Meter, Any advice would be good. Thanks.
  3. Well this one has beaten me so far. The blade is held onto the boss by two bolts. They will not budge even with me and my neighbour on the end of two wrenches. I have undone the Boss bolt but it won't leave the housing albeit loose. Does anyone have any cheats on this one. The deck is plastic so being careful with heat. Thank you.
  4. I watched a video on Youtube today re a non starting Honda push mower. The video seemed good so I thought. He removed the carb and cleaned out the main jet. All sprayed with carb cleaner and put back together. There was no mention of an Idle Jet or pilot jet ? Are they fitted to Honda's. Thanks.
  5. Tried a 3" bolt as Davey suggested would not budge. Back to square one.
  6. Are Honda engines suitable for a Hayterette body, I have used B&S in the past. Thanks
  7. Will go through all my nuts and bolts in search of one. Thanks for reply.
  8. Hot water or carefully use a heat gun.
  9. I have a copy of the Instruction Book and Spare Parts for this model. Any use to anyone in UK.
  10. My early Hayterette has probably never had its disc removed. I have used my normal tactics of drilling three holes close to the boss and using my three pronged puller, no joy. Tried heat, no joy. Now have it soaking in WD40 for how long I wonder. Has anyone else got any tips on removal. We all know how much the new disc costs. thank you.
  11. I have lost a very small 1/4 drive socket that fits the tiny bolts that hold the coil-pick ups on the engine, can anyone help please. I am after the socket - spanner size. A supplier would be good, thanks.
  12. Is anyone in S/E Essex breaking an early Hayter Rough Cutter. I am after a couple of plastic wheels but will take the whole machine at the right price. Thank you.
  13. In the past I have fitted modern B & S engines on older decks. I have a spare modern B & S 35 Classic engine which looks likes standard mower engine. It was taken from a low hours rotarvator . Will the old Hayterette cutting disc fit on the engine shaft. Hope this makes sense ! thanks.
  14. I am renovating this lovely old saw, it is fitted with a bellows / air pump which blows saw dust away from the cutting area. the bellows have perished and no longer work. Has an anyone managed to source these bellows, thank you.
