BIGJOHNG2
    27
About BIGJOHNG2
    Poulsbo, WA
    Old Iron... Tractors, Stationary Engines,Farm Equipment , Air Planes and other "Old Stuff"
9,546 profile views
  1. Do any of you gents in the UK have any idea what a Lister Junior would sell for? We don't see many of the Listers here in the US. and I have my eye on one for sale . There is an issue with the connecting rod bearing , but was told they are easy to find over there. Thanks for your help in advance. John
  2. Contact Wallfish or Factory they should be able to help you out. They do know their stuff!!! John Graham
  3. How did you ever find this article? Good work! John
  4. https://www.bmt-usa.com/schematics/ I have one just like it! You can find info on the web along with pdf drawings etc. Value??? Maybe $250. https://www.bmt-usa.com/app/download/7248228867/15_Drill_Parts_Break_Down_After_1957.pdf.
  5. Does anyone have an operator's manual and parts list for an Orline Mustang chainsaw (yellow)? I purchased this on epay a while back and need to get it running! Thanks, John
  6. I see that there are three spark plugs listed for O&R engines... Champion UY-6, CJ-8, and CJ-14. Is there one that works better than others? It seems like the UY-6 is harder to find. Any thoughts? John
  7. Thanks for the info ,John. Did you get a lot of snow from the last storm?
  8. So I have been working on my Comet pump. I was able to connect the vane ( flag ) to wire shaft which Wallfish provided. I then worked the metal with a screwdriver and secured the metal as best I could. To make the connection more secure I used a dab of epoxy. That seemed to do the trick.It is now tight.I reassembled the governor to the carb ,but it sure seems like the fit is very loose and might come flying out with the motor running. Is there a way to somehow fasten the shaft to the carb? This governor design seems a bit flaky to say the least . Any pointers? Thanks, John
  9. Roger on the idiots! I did have experience in the snow while stationed with the AF in the UP of Michigan. They did clear the snow quickly ,but with 220" or more they needed to. However, the salt on the roads tore up your car... I guess they do that in your area too. John
  10. Thanks for the help John. Too cold to work in the shop today with a low of 20F tonight. So far about 6inches of snow with a strong wind. We are used to rain , but not snow John
  11. Can someone please explain the various fuel tank multiple gas connections on the Tiny Tiger fuel tank? What are the proper connections for the various lines? Also is there a mfg manual for the tool? and MERRY CHRISTMAS TO ALL!!! John Graham
  12. Interesting Dough. Never thought about the oil mixture... that by increasing the oil would lean the fuel burn. Would the opposite then be true? Like using 32:1 make the engine run richer? How then does the mixture screw on the carb enter into the picture? Thanks, John
  13. I would like to get your consensus on the best oil to gas ratio to use on O & R engines. On the operating instructions I read , thoroughly mix 3/4 pint of outboard oil or any good # 30 SAE oil and 1 gallon of regular gasoline. The decal on the motor says mix 1/3 pint SAE 30 Heavy duty oil (MS type or equal) with 1 gal 70-80 octane gasoline.This gives a ratio of about 24 : 1. There is a bit of a difference between 3/4 pint and1/3 pint to 1 gallon gasoline What about gas ...I would guess ethyl alcohol free fuel would be best on the seals etc. However, on a modern 2 stroke weed eater that I have had for years I do use regular gas, BUT always run the machine dry after each use. Has anyone used a mixture of 32:1 and ran their machines for some time without any trouble? Your opinions ... Thanks, John
  14. David... Just curious.Did the impeller fit OK? John
  15. The points are there, the key is there, the crank threads are good, and the crank nut is there. Yeh, I am hooked! Didn't know they existed until a month or so ago when I visited an online auction, although I remember O&R plane engines when I was a kid.I do like to display engines doing work so the various tools are perfect! And did I say they are sure a lot lighter from my hit and miss engines and old tractors!! Old iron seems so much heavier than it used to be!! Who holds the record for the most tools? John
