mowerdar 98 #1 Posted November 4, 2014 Been offered a bolens g8 any body know anything about them I know it's a vert engine tractor but pictures I've seen don't match any on google cheers Darren If at first you don't succeed Use a bigger hammer Share this post Link to post Share on other sites
Triumph66 1,256 #2 Posted November 4, 2014 In my opinion, Bolens are great little tractors. The Bolens G8 denotes that it's a 8HP engine with gears. I think the engine should originally be a Tecumesh engine. Incidentally, the H denotes a hydrostatic. The G8 essentially replaced the Bolens 813 in 1973. There are other more knowledgeable members who can provide more information than I but it certainly a good little tractor and, unlike the Wheel Horse, parts are getting harder to source but they are still out there. Good luck! Share this post Link to post Share on other sites
nigel 1,880 #3 Posted November 4, 2014 the g8 was made 1973-1978 hope that helps Share this post Link to post Share on other sites
pmackellow 2,738 #4 Posted November 4, 2014 Have a look at www.tractordata.com there may be some info on there on your Bolens Share this post Link to post Share on other sites
slf-uk 914 #5 Posted November 4, 2014 From memory (happy to be corrected), the G8 was the odd one in the range with the remainder being tube frame tractors. The G8 is the newer version of what was originally called the Bolens Husky Pup's. They are often called small frame tractors. I believe the G8 has a vertical B&S engine with a transaxle similar to a early Westwood. They share a few parts with the tube frame tractors, the most notable part being the foot pegs. I have a Bolens Husky Pup 613 in my collection. If you Google "bolens husky pup" it should give you some pictures, including some pictures of mine. They are a good solid machine but not designed for ground engaging attachments. If you need any specific pictures or details let me know and I will check mine. Hope this helps Iain Share this post Link to post Share on other sites
mowerdar 98 #6 Posted November 4, 2014 Thanks for the replies missed out on it as couldn't get away form work in time shame I liked it as was different to the usual wheel horses Share this post Link to post Share on other sites
Triumph66 1,256 #7 Posted November 4, 2014 There have been a few Bolens G10s on the Bay recently if you are interested in them. Share this post Link to post Share on other sites
