MajorH 0 #101 Posted December 27, 2022 (edited) With some tinkering around I got it to run, with a caveat. Playing with the primer I was able to get the engine to run with the carb half open and the needle open to about 2.5 turns. I backed the needle out further and I was able to run it with the carb fully open. It ran this way for about 2-3 minutes then shut off, flooded or starved I'm guessing. I made some adjustments and went to pull it again and the cord pulled almost freely, there was little engagement. A couple more pulls and little engagement. I played around with it some more and it was cool now and engaging again. Do these heat up that quickly and the parts are that loose this happens, or is mine more loose than typical? I haven't tried to restart it since cool down as I wonder if something else potentially happened. Edited December 28, 2022 by MajorH Share this post Link to post Share on other sites
Wallfish 696 #102 Posted December 28, 2022 Best to start a new thread so we don't clutter this carb tutorial thread with other stuff Share this post Link to post Share on other sites
Knockdown 0 #103 Posted June 14 Where can I purchase a diaphragm arm spring Part # 21-35 key# 12. im brand new on here, knockdown Share this post Link to post Share on other sites
Wallfish 696 #104 Posted June 15 11 hours ago, Knockdown said: Where can I purchase a diaphragm arm spring Part # 21-35 key# 12. im brand new on here, knockdown Where are you located? We had resorted to making them from thin spring steel. Not sure if I have any more made but I can probably find one. Share this post Link to post Share on other sites
Knockdown 0 #105 Posted June 15 I’m in Scottsdale,Az Share this post Link to post Share on other sites
CNew 404 #106 Posted June 15 4 hours ago, Knockdown said: I’m in Scottsdale,Az What O&R engine or tool are you trying to fix? Can you start a new thread and add some photos? Share this post Link to post Share on other sites
Knockdown 0 #107 Posted June 16 It’s a carburetor and there is a tutorial on it Share this post Link to post Share on other sites
Knockdown 0 #108 Posted June 18 On 6/15/2024 at 3:46 AM, Wallfish said: Where are you located? We had resorted to making them from thin spring steel. Not sure if I have any more made but I can probably find one. Wallfish, have you located a diaphragm arm spring for me ? Share this post Link to post Share on other sites
Knockdown 0 #109 Posted June 20 On 6/17/2024 at 7:20 PM, Knockdown said: Wallfish, have you located a diaphragm arm spring for me ? Share this post Link to post Share on other sites
Knockdown 0 #110 Posted June 26 How do you contact another member? Knockdown Share this post Link to post Share on other sites
Wallfish 696 #111 Posted June 28 On 6/17/2024 at 10:20 PM, Knockdown said: Wallfish, have you located a diaphragm arm spring for me ? I have not been able to locate one. @CNew is near you in AZ. Do you have one Clint? On 6/15/2024 at 9:17 PM, Knockdown said: It’s a carburetor and there is a tutorial on it Is that all you have is a carb? Is it not on an engine? Or the engine used for a tool? That's what CNEW was asking is what engine or tool you have the carb for. Share this post Link to post Share on other sites
Knockdown 0 #112 Posted June 28 My engine is on a gold dredge and I’m trying to find a diaphragm arm spring . Mine is broken knockdown Share this post Link to post Share on other sites
CNew 404 #113 Posted June 28 I will try to look through stuff this weekend. Share this post Link to post Share on other sites
CNew 404 #114 Posted June 29 If I’m not able to find one, here are some options… https://www.ebay.com/itm/256123669540?itmmeta=01J1GVJJBPR1J8WX1WVK3BB0D8&hash=item3ba2290c24:g:K0cAAOSw7DZkm5lv&itmprp=enc%3AAQAJAAAAwKLVx5D1Ob0tKoE%2BYkmlNml%2F5vzspbV7PxdgexLSeTuoMYc%2FMON2gGASHaxf%2FniCLL6QUA1f0AFwTW50oSrDbiCNQQHRlp7kK4Hxi5je0mzqSgbb7oaY%2BbGfVQL37sPnvXr9%2F4YkGC7asx%2FOMX64CbEB%2BSJDhuw5fPiEP%2BqyARS94S6bmnFA44uQGQ5a8kACDW461c%2FkYE2jbcLQBuIxdt5IeMTshet2%2FBd8oo6aHokoypmmOsgR41MNy0W0EFXomw%3D%3D|tkp%3ABk9SR4imypuMZA https://www.ebay.com/itm/314864057496?itmmeta=01J1GVSKG4XMNHNDVMPH8WD2XR&hash=item494f5c3c98:g:SvwAAOSwDNdlGuDi&itmprp=enc%3AAQAJAAAAwITYEOgFS%2FupxKfMfPaHF4LTbh9MRT3Fr%2BFlRUMgVecJq9mloR9BYtU4Mvb1kYT5NjAkLRuVMtKgT%2B0tTqhEtGj6xf2MQYQM%2BxkYqm5gM8DczuEsDqipXStZX3sn%2B6iwYvcpCXKr7OeH%2Fzipea2kakQD9yxTsFCqPNK0XGAOqqTRnsrkL5EXMQ2Vl6eAbaYfSU7lvb8%2FSbaB8bcaSbvCP6MA2keRIO%2FX98BuoAwiLbxMBrG42Q3o5E7z%2FldhSPi%2BkA%3D%3D|tkp%3ABk9SR5a45puMZA https://www.ebay.com/itm/325699361496?itmmeta=01J1GVSKG4Q7G1MVD72VAE0GA4&hash=item4bd531dad8:g:yfEAAOSwfidkj7la&itmprp=enc%3AAQAJAAAAwBUNmKz%2F7m6F5xzH1jtpv26W2FqwHWLtaiTaEXMTyC0WGWdS7rA8lBLPHhuDVNxDHcFeFKR3gwziHqSCiZ4ETZ1Va9xQZbfCc6V4p0Dbvzpszi504dhbZHVOwfWczJByWhRb9ehCYB0TXtW5GctXqZ14KBLqf91C3hpZQ7SDRlYDm8ORKGqkuh6HUX7Au0NKK0O%2F22LJXcl7i47JHaWxggE2l%2BAMyglKGbxHayaqtu51%2FU%2F49DAhznnW66OuMsnPXw%3D%3D|tkp%3ABk9SR5i45puMZA Share this post Link to post Share on other sites
Knockdown 0 #115 Posted June 29 Thank you . I’ve tried making one out of a feeler gauge but then I lost the broken one so I don’t have a pattern.. Share this post Link to post Share on other sites
Knockdown 0 #116 Posted June 29 I ordered one from e bay , I hope it works . Thanks again, I’ll let you know if it works. knockdown Share this post Link to post Share on other sites
CNew 404 #117 Posted June 29 Ok, keep us posted if it doesn’t work. I’ll keep looking through my parts stuff just in case. Are the diaphragm and gaskets on ok condition? If the diaphragm is hard and brittle let me know. Share this post Link to post Share on other sites
Knockdown 0 #118 Posted June 29 I won’t get it until the 3 or 5th, but I’ll post when I get it and I’ll ckeck the diaphragm Share this post Link to post Share on other sites
Knockdown 0 #119 Posted July 15 I just got the carburetor installed and now I think I broke the starter recoil spring and I don’t know how to remove it . I’ve got the housing off but it appears that it’s riveted to the housing . Any ideas? Share this post Link to post Share on other sites
CNew 404 #120 Posted July 15 There should be a small cup on the center of the recoil housing that is riveted but the spring wraps around it and hooks into the cage of the recoil housing. Ther is also a retaining clip that holds the spring spool. Hard to describe. Search the Manuals section on here and there are some really good photos of how to remove the spring. I’m not sure how to add a link but here is the first page. I the Manuals section scroll down until you see the same title and you can access the entire pdf file. better yet, I forgot Wallfish added a tutorial section on Recoil repair: Share this post Link to post Share on other sites
Knockdown 0 #121 Posted July 16 I just got the carburetor installed and now I think I broke the starter recoil spring and I don’t know how to remove it . I’ve got the housing off but it appears that it’s riveted to the housing . Any ideas? thank you for the coill repair guide and yes the spring is broken. Does anyone know where to get another spring? Knockdown Thank you for the coil repair guide. I got the spool off and the spring was broken so now I need a new spring. Does anyone know where to get one?. I want to thank all of you guys for all your help and support Knockdown Share this post Link to post Share on other sites
Wallfish 696 #122 Posted July 16 4 hours ago, Knockdown said: I just got the carburetor installed and now I think I broke the starter recoil spring and I don’t know how to remove it . I’ve got the housing off but it appears that it’s riveted to the housing . Any ideas? thank you for the coill repair guide and yes the spring is broken. Does anyone know where to get another spring? Knockdown Thank you for the coil repair guide. I got the spool off and the spring was broken so now I need a new spring. Does anyone know where to get one?. I want to thank all of you guys for all your help and support Knockdown That guide also explains how to repair the spring. By heating to cherry red then allowing it to cool . It can be bent back into shape without breaking it. Can you please ask question in a new tread or a different thread instead of the this carb tutorial. We need to keep it cleaner and especially so with questions that do not pertain to the carb. Share this post Link to post Share on other sites
