simon5
Bolens identification
The shaft with the clutch attached is attached to a shaft coming out of the axle. The shaft coming out of the axle either has a spine or a flat, depending on the axle type. It is not easy so see but I would suggest the next step is to see if that is also turning. If you are lucky the problem could be the joint between the two.
Hope this helps
Iain
Thanks for the reply the shaft coming out of the axle isn't rotating. Do I need to take the whole gearbox off of the tube frame or can you access it through the top by just taking the covers off ?
It is very easy to access by doing as you suggest and take the covers off. Seat pan first then the cover. You will have a gasket between the cover and the box which can usually be reused if you take care removing the cover.
Iain
