Stormin 4,458 #1 Posted September 29, 2015 The exhaust on the Black Horse was a bit loud to say the least. Basically it is a 2" bore stainless tube with an 1-1/2" bore pipe, full of 3/8" holes and wrapped in wire wool with reducing mute, inside. A reducing mute is also inserted in the top of the outer tube. Today I decided to see if I could improve it's silencing qualities. At the top end of the inner tube, a ring is welded. This acts as a spacer between it and the outer tube. Four equally spaced tack welds hold it in place. First I cut out the ring between the welds and the end was blanked off instead of the mute. I only had enough wire wool to wrap the inner tube in, for half its length. Searching for something non-flamable/heatresistant, I found a box containing a roll of fine, stainless mesh. The type that is fitted to soffits on houses over ventilation holes/slots. This was wrapped in layers round the bottom half of the inner pipe and then all re-assembled. Lastly, the reducing mute was re-inserted into the top of the outer pipe and rain flap re-fitted. Idle and low rev running is a pleasant, low pitched beat. Also, when the flap is closed, the whistle it produced has gone. High revs, which had a rather ear shattering, strident pitch, now have a slightly subdued, mellower sound. I reckon if the whole length of the inner pipe, was wrapped in the stainless mesh, then it woud be even queiter at high revs. 1 Ian reacted to this Share this post Link to post Share on other sites
the showman 4,074 #2 Posted September 29, 2015 Sounds good Norm, all that work and typing and no photo Share this post Link to post Share on other sites
diggerjames 543 #3 Posted September 29, 2015 Good work norm nice idea mate Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted September 29, 2015 There was no way I was touching my camera, Chris. Not the state my hands were. Share this post Link to post Share on other sites
Ian 2,417 #5 Posted September 30, 2015 There was no way I was touching my camera, Chris. Not the state my hands were. You had best get a video when your hands are clean then Norm Share this post Link to post Share on other sites
