Potash123 26 #1 Posted April 20, 2016 (edited) I have acquired this nice clean looking strimmer which has fell foul of stale fuel for a few years. I fitted a new fuel line and return line and a new diaphragm and primmer bulb. It would seem that the end plate of the carb that holds the bulb and covers the diaphragm is blocked solid. I cannot blow any air through this small plate. I have tried carb cleaner to no avail. It has hardly been used so I don't want to throw it. Suggestions would be appreciated. My carb is a Zama GND-18. Regards Colin PS I am about to restore another Hayter 21 so will be back with a few more questions in due course. Edited April 20, 2016 by Potash123 Share this post Link to post Share on other sites
nigel 1,880 #2 Posted April 20, 2016 I would say try an ultrasonic cleaner it normally works for us Share this post Link to post Share on other sites
Potash123 26 #3 Posted April 20, 2016 I have one of those sonic tanks, how long shall I leave it on for, thank you. Share this post Link to post Share on other sites
C-101plowerpower 548 #4 Posted April 20, 2016 Is it one of those standard carbs? If so i'd find annother one and put that on Share this post Link to post Share on other sites
nigel 1,880 #5 Posted April 20, 2016 i normaly put parafin in mine and leave it on for a couple of mins Share this post Link to post Share on other sites
Potash123 26 #6 Posted April 21, 2016 I pulled the carb off, put in the ultra-sonic for ten mins. New diaphragm and gaskets, job done its running again. A new carb was £50 plus vat ? So I am happy. Regards Colin 1 diggerjames reacted to this Share this post Link to post Share on other sites
nigel 1,880 #7 Posted April 21, 2016 cant beat an ultra sonic Share this post Link to post Share on other sites
Potash123 26 #8 Posted May 4, 2016 Still running well, however petrol pouring out cap hole ( about 2mm ) I found another cap with a gauze inside the hole restricting the flow. It still lets fuel out the cap. Am I simply just putting too much fuel in tank. This is my first petrol strimmer. Thanks. Share this post Link to post Share on other sites
Stormin 4,458 #9 Posted May 4, 2016 That's a rather big hole to my way of thinking. 1mm should be sufficient. If your brimming the tank, then yes, your putting to much in. But a photo would help. Share this post Link to post Share on other sites
nigel 1,880 #10 Posted May 4, 2016 Should normally have a rubber in the top of the cap Share this post Link to post Share on other sites
Stormin 4,458 #11 Posted May 4, 2016 How does the tank breath then, Nigel? Though thinking about it, I don't think my strimmer has a hole in the fuel cap. Share this post Link to post Share on other sites
Hillsider 16 #12 Posted May 5, 2016 Almost certainly the breather valve has come adrift from the underside of the filler cap. The valve is normally held in place by the moulding and spring clip that also secures the fuel cap restraint line that in turn hooks into the fuel tank to prevent the cap from getting lost. New caps are still available if you search the internet you will not be disapointed. Share this post Link to post Share on other sites
nigel 1,880 #13 Posted May 6, 2016 19 hours ago, Hillsider said: Almost certainly the breather valve has come adrift from the underside of the filler cap. The valve is normally held in place by the moulding and spring clip that also secures the fuel cap restraint line that in turn hooks into the fuel tank to prevent the cap from getting lost. New caps are still available if you search the internet you will not be disapointed. thats what i meant Share this post Link to post Share on other sites
