wurzel 117 #1 Posted September 8, 2016 small video of QT17 leveling gravel 1.mp4 2 HeadExam and Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted September 8, 2016 Does a good job. 1 wurzel reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #3 Posted September 9, 2016 Excellent video, you ran out of driveway, come do some of mine, lol. Did you know they made that same tractor with a 16hp Kohler k341 single cylinder, the QS16? Share this post Link to post Share on other sites
wurzel 117 #4 Posted September 9, 2016 9 hours ago, HeadExam said: Excellent video, you ran out of driveway, come do some of mine, lol. Did you know they made that same tractor with a 16hp Kohler k341 single cylinder, the QS16? thanks yes was it called a QT 16 though ive got a G16XL as well with a tecumseh oh16 but that has a belt drive rear tranny but shaft drive from engine cheers nick 1 HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #5 Posted September 9, 2016 46 minutes ago, wurzel said: thanks yes was it called a QT 16 though ive got a G16XL as well with a tecumseh oh16 but that has a belt drive rear tranny but shaft drive from engine cheers nick Actually the QT16 was a 16hp Onan Twin cylinder and the QS16 was the 16 hp Kohler single cylinder, the Q stood for Quiet model or Quiet line and the T and S stood for twin or single. The QT series and XL series Medium Frame tractors had the engine oriented 180 degrees differently than the earlier Bolens tractors. 1 wurzel reacted to this Share this post Link to post Share on other sites
wurzel 117 #6 Posted September 9, 2016 1 hour ago, HeadExam said: Actually the QT16 was a 16hp Onan Twin cylinder and the QS16 was the 16 hp Kohler single cylinder, the Q stood for Quiet model or Quiet line and the T and S stood for twin or single. The QT series and XL series Medium Frame tractors had the engine oriented 180 degrees differently than the earlier Bolens tractors. G16XL layout 1 Triumph66 reacted to this Share this post Link to post Share on other sites
wurzel 117 #7 Posted September 9, 2016 QT17 layout 2 HeadExam and Triumph66 reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #8 Posted September 9, 2016 I've had both models, and both drove the transmission off the flywheel side, while earlier tube frames and large frames powered the transmission off the PTO side. Not saying one is better, just different. I noticed you have the same issue I have, the current battery is too big for the plastic hold down. 1 wurzel reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #9 Posted September 9, 2016 Good video and I like the Bolens scribed plastic battery clamp; a nice touch. 1 wurzel reacted to this Share this post Link to post Share on other sites
wurzel 117 #10 Posted September 9, 2016 25 minutes ago, HeadExam said: I've had both models, and both drove the transmission off the flywheel side, while earlier tube frames and large frames powered the transmission off the PTO side. Not saying one is better, just different. I noticed you have the same issue I have, the current battery is too big for the plastic hold down. i prefer the Hydro much nicer to use and i like the sound of the kohler twin not sure if its the correct battery hold down 1 HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #11 Posted September 9, 2016 6 minutes ago, wurzel said: i prefer the Hydro much nicer to use and i like the sound of the kohler twin not sure if its the correct battery hold down I think the battery hold down is correct, just not the battery. The Hydro is awesome on the Bolens, but late model geared tractors aren't as common, so nice to see them as well. Thanks for the pictures. 1 wurzel reacted to this Share this post Link to post Share on other sites
