neil 524 #1 Posted February 1, 2014 I am looking to build an E tank so that i can remove old paint from my tractor panels, does anyone know how this is done ? Share this post Link to post Share on other sites
meadowfield 1,901 #2 Posted February 1, 2014 Plenty of threads on this elsewhere Neil, but it's pretty easy to start small and work up. So I'd start with a small tub/barrel.... Fill to the top with water, add a few tablespoons of washing Soda crystals, not bicarbonate! Find a piece of clean steel and fasten it to the inside running down to the bottom, I usually put this inside a piece of plastic waste pipe with holes in. This stops it shorting out on the piece you are cleaning. Find either a good battery charger, or a good battery with a reasonable charger. You need a good 12v supply. Connect the positive to the clean metal with wire/crocs clips. Try not to let the clips go into the solution. Connect the negative to the dirty piece and lower it into the tank. If you have a reasonable charger the current will move up to around 1A depending on the size of the anode and piece being cleaned. After a few mins you should see bubbles coming from the piece being cleaned, after an hour there will be a brown scum floating on the top. The rest is patience, some pieces clean pretty quick, some take days/weeks. You have to keep cleaning the anode and sometimes help by scraping some of the loose paint away. I think that kinda covers the basics Share this post Link to post Share on other sites
Anglo Traction 1,018 #3 Posted February 1, 2014 Everything that Mark has mentioned above. If you haven't done so yet , look it up on the Web, There are important things to understand about what kind of metals must never be put in the E-Tank. They can produce toxic chemical gasses (basically no Non Ferrous). The normal process on Mild, Black and Carbon steels, also Cast Iron produces Explosive Hydrogen Gas, must be well ventilated area. I also read somewhere to avoid using Battery Chargers that have an 'Auto Cut Out'. Read everything you can find on the subject is the best advice 1 neil reacted to this Share this post Link to post Share on other sites
neil 524 #4 Posted February 1, 2014 safety being paramount Richard Share this post Link to post Share on other sites
nigel 1,881 #5 Posted February 2, 2014 talk to ian neil he has a good one Share this post Link to post Share on other sites
C-101plowerpower 548 #6 Posted February 3, 2014 Everything that Mark has mentioned above. If you haven't done so yet , look it up on the Web, There are important things to understand about what kind of metals must never be put in the E-Tank. They can produce toxic chemical gasses (basically no Non Ferrous). The normal process on Mild, Black and Carbon steels, also Cast Iron produces Explosive Hydrogen Gas, must be well ventilated area. I also read somewhere to avoid using Battery Chargers that have an 'Auto Cut Out'. Read everything you can find on the subject is the best advice i wouldn't worry about the hydrogen to much, i tried lighting it and it gave some pops. if your shack is airtight okay but otherwise nah, just leave the door open a bit Koen Share this post Link to post Share on other sites
Anglo Traction 1,018 #7 Posted February 3, 2014 What you say Koen is pretty well understood and probably a foregone conclusion. The exception is if you have low windows or door openings, the Hydrogen will build up and remain at the highest point and may not necessarily be blown away or diluted by ventilation to a point below combustibility. Then you consider the location of your Flourescent Lights and how they become illuminated when you turn them on !! . The 'Starter' in the lights create a spark which is open to the atmosphere hydrogen and oxygen.....Boom Baby !!! Guaranteed to raise the Roof Share this post Link to post Share on other sites
Ian 2,417 #8 Posted February 8, 2014 I miss my old E-tank.. Big enough to fit a bonnet in.. Or even a body My current E-Tank.. A bit smaller than my old one but still a handy size.. The wheel had only just been put in.. When the wheel came out a few days later you could brush the paint off with your finger. Share this post Link to post Share on other sites
