Aiberdonian 98 #1 Posted March 12, 2018 It's not in the shed anymore, dragged it out today as it's on it's way to a new owner who has a collection of early stationary engines. I am hoping someone may be able to advise what it may have been used for. I saved it from being broken up for it's copper and brass by a local scrap dealer about 35 years ago, I just couldn't let him break it up as it should really be in a museum. It's a Crompton DC dynamo serial no.6270, 70 Volt 25 Amp output at 1280 RPM and I believe it could well be pre 1900 but I have no idea what it would have been used for and whether it had been driven by steam, petrol or maybe waterwheel or what equipment would have run off the 70 Volt output. Preston Services had a similar one a few years ago but it had 3 armature supports and was 110 Volt output. 5 Stormin, Anglo Traction, Cub Cadet and 2 others reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,016 #2 Posted March 12, 2018 Nice old piece and glad it was saved. Look's like an early Domestic lighting Generator and as you say probably powered by something like a Lister or similar, Is that Insulation Block where the Terminals are on top ..a block of Ebony, Bakelite, Paxolin or Resin?. Share this post Link to post Share on other sites
Aiberdonian 98 #3 Posted March 12, 2018 16 minutes ago, Anglo Traction said: Nice old piece and glad it was saved. Look's like an early Domestic lighting Generator and as you say probably powered by something like a Lister or similar, Is that Insulation Block where the Terminals are on top ..a block of Ebony, Bakelite, Paxolin or Resin?. I don't think it's ebony, it's not dark enough but it is definitely some type of wood. New owner has a 1905 5HP hit and miss engine that he intends to drive it with(can't remember the make but it's not a common one) Share this post Link to post Share on other sites
