Scottwilson 76 #1 Posted June 25, 2018 Picked this up today and was told it’s for wheelhorse it looks like a toolbar attachment it has a rake on it at the moment . Anyone have any info or know if it is or isn’t wheelhorse? Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted June 26, 2018 Can't say for sure, but could be. The colours right, though the rake part could be off something else. Should fit anyway. Share this post Link to post Share on other sites
Scottwilson 76 #3 Posted June 27, 2018 On 6/26/2018 at 6:39 AM, Stormin said: Can't say for sure, but could be. The colours right, though the rake part could be off something else. Should fit anyway. That was my thoughts . It is very similar to the toolbars I’ve seen on two wheeled machines. Share this post Link to post Share on other sites
HeadExam 1,783 #4 Posted June 28, 2018 From 1960 on Wheel Horse 4 wheel machines used a slot hitch that the tongue on your implement would have had to be longer to pin on, so It may have been a walk behind. 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,016 #5 Posted June 28, 2018 I reckon Alain is right, the WH Cultivator model is an example and is/was in 2 parts, Mid Mounted and Rear Mounted. The rear part is this- But it only had 4 Standards and Shovels on the Rear and 3 on the Mid Section and both sections are raised using the Lift Lever. Should be no reason for your example to perform ok, but may need extending to prevent contact with the rear wheels on the turn. Edit- Model # is 7-1723 and requires either a Slot Hitch (pictured) or a Clevis Hitch. Seems each WH attachment was specific to a duty and not a unit with various fittings. Other makers Attachments were offered by WH as options though. 1 HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #6 Posted June 28, 2018 After you mention the issue with turning it is obvious that whatever machine it did belong to must have had a hitch that extended rearward more than most tractors did Share this post Link to post Share on other sites
Scottwilson 76 #7 Posted July 2, 2018 Thank you for the input guys I may have a look at extending the hitch bar as it’s a cool looking little thing to put behind once using the gang mowers . Share this post Link to post Share on other sites
