Fix'em all 49 #1 Posted November 7, 2018 (edited) Lucky enough to pick up this rare 1950's manual to go with my equally rare Versatiller Mk 1 Edited November 7, 2018 by Fix'em all 1 Stormin reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #2 Posted November 7, 2018 If that was the one on ebay you outbid me then Glad to see its gone to a good home Share this post Link to post Share on other sites
Fix'em all 49 #3 Posted November 7, 2018 Could be Paul !! I think i am correct in saying you already have one of these, so it's good to share The book mentions a separate manual for the 75 engine, that would be a nice to have. Share this post Link to post Share on other sites
pmackellow 2,738 #4 Posted November 7, 2018 11 minutes ago, Fix'em all said: Could be Paul !! I think i am correct in saying you already have one of these, so it's good to share The book mentions a separate manual for the 75 engine, that would be a nice to have. Absolutely, it is indeed good to share I have not seen the engine manual yet but you never know... Share this post Link to post Share on other sites
Fix'em all 49 #5 Posted November 13, 2018 Does anyone know anything about the Versatiller MK3. I don't think it had the same engine as the first 2 models but interested what engine it had fitted. Share this post Link to post Share on other sites
pmackellow 2,738 #6 Posted November 14, 2018 I have a Mark 4 thats got a Tecumseh 4 stroke in it... Share this post Link to post Share on other sites
gt7501 0 #7 Posted July 8, 2020 HI, I am in New zealand. Ihave a versatiller the same as the 1 in the picture. It is all complete but i need a starter recoil spring. Any idea where i can find one. Share this post Link to post Share on other sites
Fix'em all 49 #8 Posted July 8, 2020 Hi, I thought mine was broken but it was just seized up. Taking it apart is not an easy job but if you do need a spring I doubt you will get one & will have to make something up. You are lucky to find this as they are very rare & I assume you understand the significance of the engine fitted to these. Share this post Link to post Share on other sites
nigel 1,880 #9 Posted July 8, 2020 So which mk had the kickstart ? Share this post Link to post Share on other sites
Fix'em all 49 #10 Posted July 8, 2020 That was the MK2. I also had one of those but stupidly sold it 1 nigel reacted to this Share this post Link to post Share on other sites
nigel 1,880 #11 Posted July 8, 2020 7 hours ago, Fix'em all said: That was the MK2. I also had one of those but stupidly sold it I think I sold one of them to paul Share this post Link to post Share on other sites
gt7501 0 #12 Posted July 8, 2020 16 hours ago, Fix'em all said: Hi, I thought mine was broken but it was just seized up. Taking it apart is not an easy job but if you do need a spring I doubt you will get one & will have to make something up. You are lucky to find this as they are very rare & I assume you understand the significance of the engine fitted to these. Thanks for that, yes i have looked into the engine and it is made beautifully. I was given it by an older man who had a mower repair shop. he was unable to repair it because of the broken spring so i have not started it. it has been in storage at my friends place. I have restored it with a good coat of paint. it still has the versatiller tnansfer down the handle tube. I should be getting it back soon so i will try to post a pic. Rgds Graham. Share this post Link to post Share on other sites
Fix'em all 49 #13 Posted July 10, 2020 Have you confirmed that the spring is broken or just in need of lubrication like mine was. They were fitted with a strong wire pull cord because of the difficulty in getting to the mechanism. I did it by getting a small gap between the casings wide enough to fit 3 nuts in. I then screwed bolts in, rotated it slightly so the bolts push against the other casing & force the points cam assembly off the shaft. You need to mark the position of the points cam assembly first. Share this post Link to post Share on other sites
pmackellow 2,738 #14 Posted July 10, 2020 On 7/8/2020 at 5:54 PM, nigel said: I think I sold one of them to paul No mate, not to me... Share this post Link to post Share on other sites
nigel 1,880 #15 Posted July 10, 2020 4 hours ago, pmackellow said: No mate, not to me... Your sure ? Or was it steve dennis I realy thought you had it Share this post Link to post Share on other sites
nigel 1,880 #16 Posted July 10, 2020 Where did you get your one from then paul Share this post Link to post Share on other sites
pmackellow 2,738 #17 Posted July 11, 2020 11 hours ago, nigel said: Where did you get your one from then paul I think Steve had yours mate, my Mark 2 came from South Wales Share this post Link to post Share on other sites
