case 8230 1 #1 Posted December 17, 2019 (edited) Looking for carb parts for o&r motor can you give me some help please need needle assembly mine is broke off. Maybe a diaphragm gasket kit. Clip for throttle cable Edited December 17, 2019 by case 8230 forgot few things Share this post Link to post Share on other sites
JUST O&R 237 #2 Posted December 17, 2019 (edited) We may be able to help. If its the arm with the rubber tip That may be a problem the seem to be like hens teeth . carb diaphragms are not a big deal a good friend of mine just sent me a care package or there are a few others that have a lot more parts. cable I'm not sure. I have a older one for parts but would need to dig it out to see if its the same. By the way welcome. p.s. if you look in the carb thread there is a butt load of information. Edited December 18, 2019 by JUST O&R 1 case 8230 reacted to this Share this post Link to post Share on other sites
Webhead 95 #3 Posted December 17, 2019 I have everything that you need... Share this post Link to post Share on other sites
CNew 406 #4 Posted December 17, 2019 Welcome! Sounds like others have you covered but happy to help if I can. Share this post Link to post Share on other sites
case 8230 1 #5 Posted December 17, 2019 3 minutes ago, Webhead said: I have everything that you need... Okay how do I get ahold of you. Thank you so much for the help. Share this post Link to post Share on other sites
JUST O&R 237 #6 Posted December 19, 2019 I checked the one that was under the bench its to old . This one have has no throttle cable . hopefully weghead can help with that . just post if we can help these guys are the best if you cant find it here you probably wont find it. Share this post Link to post Share on other sites
JUST O&R 237 #7 Posted December 19, 2019 Hope factory is doing ok . Miss him here he has all the rite answers. Share this post Link to post Share on other sites
factory 487 #8 Posted December 21, 2019 On 12/17/2019 at 10:45 PM, case 8230 said: Looking for carb parts for o&r motor can you give me some help please need needle assembly mine is broke off. Maybe a diaphragm gasket kit. Clip for throttle cable Probably a bit late (I had to take a break following a bereavement), the needle valve assembly is very easy to break if overtightened due to being made from thin sections of brass. I'll have a look at mine to see if it uses the standard clip for the throttle cable. David P.S. I've moved these posts about the Drillgine parts from the TT thread to this new thread. Share this post Link to post Share on other sites
case 8230 1 #9 Posted December 22, 2019 Okay got new needle an diaphragm in an still wont suck gas to the carb an answers what to do now Share this post Link to post Share on other sites
case 8230 1 #10 Posted December 23, 2019 Okay finally got it running thanks everyone for the help. 1 CNew reacted to this Share this post Link to post Share on other sites
