Tonyc 3 #1 Posted May 31, 2020 Hi all I bought a westwood gemini and I'm trying to get it started , I need some help sorting out the throttle and governor linkage setup .hopefully someone on here can help me out please Share this post Link to post Share on other sites
Fix'em all 49 #2 Posted May 31, 2020 Hi Tony, take a few photos of how it all looks now & what your issue is. I am sure someone on here can help. I assume it is the original Suffolk engine Share this post Link to post Share on other sites
Tonyc 3 #3 Posted May 31, 2020 Hi thanks for the reply , yes it's the Suffolk engine, I've got a spark so all good there but I need to know how the governor plate and linkage and springs are set up . Also the pulley that attaches to the clutch that applies the tension is missing and I dont know what one to get and how its held on and finally lol the fuel tap is leaking so need to renew it if you could suggest a replacement please Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted June 1, 2020 Well that shows how much I know about Westwood Gemini's. 1 Fix'em all reacted to this Share this post Link to post Share on other sites
Tonyc 3 #5 Posted June 1, 2020 Ok so I've sorted the linkage but I really need to know what pulley I need for the clutch and how its held in place and what fuel tap would fit the tank Share this post Link to post Share on other sites
Tonyc 3 #6 Posted June 2, 2020 Hi me again does anyone own or know where I can get the pulley that takes up the tension on the belt please or maybe a part number even a pulley that I can get that would work from another model cheers Share this post Link to post Share on other sites
Fix'em all 49 #7 Posted June 2, 2020 Cannot see from your photo but is the whole arm missing or just the bearing section that pushes on the belt. If you can find a cheap knackered Flymo DM most parts are interchangeable. The belt on these is A20.5 as it is just a bit longer than the A20 on the DM Share this post Link to post Share on other sites
Tonyc 3 #8 Posted June 2, 2020 Hi thanks for info , the arm is there just pulley I need if I knew the diameter and width of it I could probably find a pulley off the net Share this post Link to post Share on other sites
Fix'em all 49 #9 Posted June 5, 2020 Morning, not sure of the dimensions as I don't have mine anymore, but you can make one with a couple of bearings & a couple of large washers. Just measure the diameter of the remaining stub & how much length you have available before the circlip groove. When I did this previously I put a slightly larger diameter washer on each end to act as a lead for the belt. It all depends how much length you have before the circlip. Share this post Link to post Share on other sites
Tonyc 3 #10 Posted June 5, 2020 Here is what someone sent me and here is what I found on the net but it's a bit bigger Share this post Link to post Share on other sites
Fix'em all 49 #11 Posted June 14, 2020 It doesn't need to be big. The bore & length are the important dimensions Share this post Link to post Share on other sites
Tonyc 3 #12 Posted June 14, 2020 Thanks I've sorted pulley problem now and had a quick go in the garden with it it works a treat , what a great bit of kit 3 Fix'em all, WestwoodW8Gazelle and Stormin reacted to this Share this post Link to post Share on other sites
