Rennie 2 #1 Posted July 25, 2020 (edited) Hi, im a new member that knew nothing a out the existence of O & R engines till a week ago when i became the owner of a Danarm Hedge Trimmer. Ive decided to attempt to restore it, but whilst it seems in a reasonable state need some help in where i might look for parts. Testing the magneto with a multimeter it appears to be dead ( broken HT im guessing) the engine is missing a tank too. Anyone know anything about this unit? (Photo inc) its age etc? Thanks in advance 😊 Edited July 25, 2020 by Rennie 2 pmackellow and factory reacted to this Share this post Link to post Share on other sites
Wallfish 705 #2 Posted July 25, 2020 Those hedge trimmers are the same type as others and many companies branded them under their own name. The tool part looks complete so that's good and we can help with engine parts if you need them. It's rare to have a bad coil but yours looks to be missing the primary and secondary small wires. That type of trimmer used a vertical style fuel tank. Good clean original tanks can be difficult to find but making a replacement might be a good idea until you can find one if it matters. David @factory should be able to help with dating it. Knowing your location would help too Share this post Link to post Share on other sites
Rennie 2 #3 Posted July 25, 2020 Thanks WallFish, those cables are there disconnected them, whilst testing it with my multimeter. Im in Wales, UK. Will check out your contact. Good to know about the thank, will see what vertical tanks are about. Would there have been a send and return fuel pipe? Share this post Link to post Share on other sites
Wallfish 705 #4 Posted July 25, 2020 Just a single fuel line to the carb. The most common issue for a no spark condition is the points. They're located under the flywheel and under that little panel. Clean the contacts well and also clean the spring where it contacts the little post. This is a pic of the tank although the trimmer is different Share this post Link to post Share on other sites
factory 487 #5 Posted July 26, 2020 That explains what Danarm were importing & rebranding, it's a Grow Gear trimmer with a planetary gear box (not the same as Orline, etc), see the Grow Gear advert part way down the page here; The fuel tank is plastic & fits the two smaller holes on the gearbox. My later Grow-Gear for comparison (has different handle but other-wise the same). David 1 Rennie reacted to this Share this post Link to post Share on other sites
Wallfish 705 #6 Posted July 27, 2020 20 hours ago, factory said: planetary gear box (not the same as Orline, etc Do you happen to have any pics of how that gearbox is set up on the inside? The case itself looks just like the Orline and others except for the branding and those tank tabs. Share this post Link to post Share on other sites
Rennie 2 #7 Posted July 27, 2020 Good afternoon Wallfish, probably gonna start the strip down weds evening, so will take a photo and post it up 😊 Share this post Link to post Share on other sites
factory 487 #8 Posted July 27, 2020 8 hours ago, Wallfish said: On 7/26/2020 at 2:33 PM, factory said: planetary gear box (not the same as Orline, etc Do you happen to have any pics of how that gearbox is set up on the inside? The case itself looks just like the Orline and others except for the branding and those tank tabs. I meant the reduction gearbox part, i.e. the section between the cutter/eccentric housing and the engine. And no I haven't looked inside mine as there are enough things in bits here. David Share this post Link to post Share on other sites
