ChrisE 0 #1 Posted April 11, 2014 Hi All, This is my first post on this forum. I hope you can help me! I recently purchased a AC120 powered Bantam. It was in a bit of a sad state with rust, but not bad considering it has been exposed to the elements for so long. I am keen to turn over the engine, but my oil dipstick is missing, hence I can't be sure of the correct oil level. Can anybody give me a few measurements of the stick so I can make a replacement? Share this post Link to post Share on other sites
C-101plowerpower 548 #2 Posted April 11, 2014 first of all you're probably the first african guy on here Koen Share this post Link to post Share on other sites
nigel 1,876 #3 Posted April 11, 2014 welcome chris, the man you want is S1g i am sure he will be able to help he normaly pops in most days Share this post Link to post Share on other sites
pmackellow 2,738 #4 Posted April 11, 2014 Hello Chris, welcome aboard,as Nigel said Gareth (S1g) is yout man for all things Howard Share this post Link to post Share on other sites
S1g 579 #5 Posted April 11, 2014 Hi there's one in my storage unit, ill be there on Sunday, and take photos, measurements etc,remind if you haven't heard by Sunday evening. Share this post Link to post Share on other sites
Ian 2,417 #6 Posted April 12, 2014 Hi Chris, I can't help you with your dipstick, but Welcome to MOM.. Good to have you aboard Share this post Link to post Share on other sites
ChrisE 0 #7 Posted June 8, 2014 Hi All. Thank you for the welcoming. Still no luck with the oil stick. I am also not too sure about oil grade as well. I plan to replace the oil sump gasket as it is leaking. I'll make some height measurements of the oil slinger and try and fashion a crude oil stick out of some brass rod. Before: Partial rust removal and cleaning: First coat of paint after sanding and degreasing: I need to strip and paint the engine. I am still deciding if I should go for an LPG convertion; the carb is troublesome. Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
S1g 579 #8 Posted June 8, 2014 Hi I've got the stick on the side at my work, sorry totally forgot to measure it, will do. Share this post Link to post Share on other sites
Vig 1 #9 Posted June 10, 2014 Saw this post after trawling the net for other info measurements are:- 118mm from the washer shoulder to the end part (sump0 dipstick The rod diameter is three sixteenths the rod is cut to form a half moon in profile at dipping end to a total length of 20mm there is a line halfway at 10mm ... this i take to be the median oil level.. this bantum is new to me as well and i am not familiar with the measurement yet either regards Vig 1 ChrisE reacted to this Share this post Link to post Share on other sites
ChrisE 0 #10 Posted August 20, 2014 Thanks Vig! I will use you measurements this weekend. I polished the valves and corrected the clearance. The intake valve was not opening completely. It has so much more power now. Now I have a new problem; the key sheared in the keyway and cracked the flywheel. I am guessing it is cast iron? How can I repair this? The keyway is damaged as well. Regards, Chris Share this post Link to post Share on other sites
ChrisE 0 #11 Posted August 23, 2014 Ok. I did the spark test, it looks like the flywheel is cast aluminium with a steel ring to hold the key. The engine runs beautifully between the flywheel loosing itself; I was able to give my veggie patch a final pass before I start on seeding and planting. The keyway on the crank is looking a little bit buggered. I guess the likelihood of finding a spare flywheel and crank is next to none. I may have to replace the entire engine. Maybe I can make a simple air compressor out of the old AC120? Does anybpdy know the bearing sizes for the wheel axle? I have a bit of play in the RHS. I don't want to damage the gearbox. Cheers, Chris Share this post Link to post Share on other sites
