revmix
    24
About revmix
    East Brunswick NJ
3,778 profile views
  1. The cute little machine $pending plus shipping cost
  2. I'm in central Jersey & can pick up the Shark helicopter any time when it's convenient for you
  3. I'd be interested, don't throw them away
  4. if the saw is turned sideways or nose down the fuel splashes into the tube & leaks on the bottom, no big deal, keep the machine near level
  5. it's normal, there is no check valve on the copper tubing, a rubber duckbill can be installed on the bottom
  6. you could also remove the bar & chain so no load on the gearbox, much easier testing the engine
  7. the tube looks clean if gas comes through & no need to remove the tubing [mine was plugged with oily sawdust & cleaned it with wire pushed through], try to run the engine spraying fuel-mix into the carb, I always do that before getting into the carb
  8. I have the same Mustang & color, that copper tubing is the vent & goes up to the top of the fuel tank, can be seen next to the fuel cap opening, maybe the needle valve needs to be adjusted or the hole cleaned [built up dust due to long storage], also the idle RPM maybe too low, when starting give it a bit throttle
  9. revmix
    revmix
  10. Hello all, I'd like to get some info if & how CDI can be used instead of the spark coil?
