As best as I can tell this is a first generation drillgine with the O&R type 100 3/4hp engine (serial 013352). I bought this drill a while back. It was seized up tight. I tried my best to save this one. It sat in my heated ultrasonic for three days vibrating away. I even went to the extent of putting the crankcase in my lathe to cut the cylinder off to save the piston and rod. Sadly the engine was too far gone and it was not meant to be. When my parting tool grabbed the port on the steel liner the crankcase got pulled out of the chuck on my lathe and bye bye went the crankcase. I was able to save the crankshaft from this mess. I am not going to get around to this project anytime soon so I figured I would offer it up for parts should someone be needing them for their drillgine, or if someone wanted to be ambitious and rebuild this one. I did find one repair on the drill which actually looks well done. The drill case has been tig welded up and someone added a little bent steel bracket to better support the handle. I realize this is not in great shape, and I am not looking to get rich on it. I will ship this drill anywhere in the USA. Please send me a private message if interested with your offer.
Thanks
Chris
Thank you very much for your in depth replies David!
I would have never been able to figure all of that out. My hat is off to you. You must have a wealth of O&R literature in your collection.
Now that I know what it is, I will have to pull it all down and make it as right as possible. These little bicycle engines are really neat.
Chris
David,
The sticker on the blower shroud says "Manufactured and warranted by O&R Engines Incorporated 3340 Emory Street Los Angeles California USA"
Chris
I love the gear reduction feeding a gear reduction. I have a much larger Jaeger double drum winch with a 31horsepower Wisconsin inline 4 cylinder engine that works in a similar fashion, only It is like 300x the size. Yours looks much more manageable. I cannot wait to see this thing work. I hope you have something you can winch with it.
Chris
CNew, I ended up buying the O&R 20 crankcase off of ebay. I am not sure what to think as of right now. There is some very odd wear patterns in the plated cylinder. I am wondering if this engine has only a few minutes of run time on it, as the rings seem to have been jumping in the cylinder. I will put the cylinder in my Sunnen honing machine and see what a few revolutions do with the junior hone, carbide stones and flood cooling. The piston looks phenomenal. I hope to use the best parts possible to fix the 20A powered sprayer I have.
Chris
Here is another one of my O&R pumps. Sadly this one also came from the man my Lancaster mini pump came from which was seized up hard. This one looked and felt promising, and bam what do you know, Richard from New Jersey shows up and ruins your day! I cannot believe he hot glued the flywheel to the crankshaft. It turned with compression and spark! I see that the pump has a tag which says 0.85hp @ 6000rpm, and the blower shroud on the engine has the remains of a 1hp decal. I measured the bore/stroke and it is a 21.9cc engine. Type # 133. From reading online the 133 should be olive drab 0.85hp decal shroud of this style. I bet he tried to run it and that flywheel blew the original housing to smithereens. Thankfully I have a donor 0.85hp olive drab blower housing in this style in my parts drawer. I am done buying O&Rs from this guy. He burnt me twice in a row. There may be a 'repair' to the pump housing too, as it appears to be tig welded up just above the drain port. I have not seen another in person, so not sure what exactly to expect. At least it is clean and presentable now, until I find a crankshaft and the necessary parts to fix it.
Chris
Thanks for the link, I have bought from Bryce before, he is a little less than honest with his descriptions. I think it is still worth the gamble because of the price. I will likely purchase the crankcase this week.
Chris
For your amusement is the rare 6 port O&R engine! This engine was put away "running", as I am sure most are! This little O&R must have been dug out of a lake bed. The muffler was completely packed full of mud. I bead blasted the engine and submerged it in my heated ultrasonic cleaner for three days. I gave the cylinder a wiggle with my O&R cylinder removal tool, and snap, the connecting rod blew in half. With the cylinder separated from the crankcase I re-blasted the engine this time getting under the piston, and into the crankcase. The crankcase free'd up within an hours time in the ultrasonic. The piston was a job the grease gun fought with. I am surprised to say that this little casting can actually take 5,000psi of force, as the bypass on the pump hit a few times as heat was applied. The little piston finally came out, and it was rusted and corroded all over. It turns out that the mud in the muffler eat through the cast iron liner into the cylinder. So much for trying to save the cylinder! This one is a goner. I will have to put a donor piston/cylinder/rod in this one when I go about replacing all of the needle bearings. I thought you guys would like to see the pictures even though the situation isnt the greatest. The pump has been loosely reassembled and now has spark, so that is a good thing!
Chris
Thanks! I appreciate it. I think mine was run on 50:1 or straight gas at some time. It is on an insecticide sprayer so it is certainly worth fixing! I hope to pull the cylinder soon and see how the bore looks. It appears to be a 'chrome' plated bore which I was surprised at. I was hoping it would have had a cast iron bore like the little compact engines.
Chris
Thanks! I was really scratching my head on this one, as I have a lovely Orline chicken power in my collection, and there are a LOT of small differences between these two units. I would love to complete this one, as I want to run two of them on my bicycle at least once!
Also as a side note, I forgot to mention. There is no primer on the AEP bicycle engine. This carburetor was on this engine when I bought it, but there were a few other busted up carbs in a bucket of loose parts with it, and I wasnt sure which it had. Would this have had a primer carburetor?
Also, if anyone has a type number for this AEP bicycle engine, can you please share it. I will need to hunt down the right parts for it at some point.
Chris
You have some really nice O&R stuff John! What is your "Lapadary saw" Is that a mini table saw? Is there an official count on all of the machinery O&R powered? Just when you think youve seen them all a dozen other oddballs show up! I cannot believe they had a powered earth auger. I really like your fogger, compressor and power pole.
Chris
I picked up what I believe to be an O&R Compact III Chicken power bicycle engine. It was seized up when I bought it. I have since blasted and free'd it up. It will certainly need a lot of love. However what I am curious about is the recoil housing, and the manifold/muffler on this engine. All of the Orline/Chicken power bicycle engines I have seen had the common 'teardrop' O&R blower shroud. This one has the later boxy blower shroud. This one also has an odd exhaust manifold with a threaded end. This is the first I have seen a threaded exhaust manifold on an O&R. Is this engine just an odd combination of parts? There are no numbers on the engine anywhere, and sadly the one sheet metal shroud that would have had some stamped information is missing. There are no numbers stamped on the flats of the crankcase.
Chris
Does anyone have a 400081 piston or 200023 rings for an Ohlsson & Rice 20A engine?
I havent been on here in a few years. I finally scored a 20A for my collection. It does run, but the piston is rather scuffed when looking thru the exhaust port. I will have to pull the cylinder and check it out. These seem to be very hard engines to find. I only have one in my collection of ~25 O&Rs. Were they only used on chainsaws, hedge trimmers and an outboard? Seems like there are none of them out there compared to the common O&Rs.
Chris
I would never consider using a steel flywheel key in a soft aluminum flywheel. It is just asking for trouble. It is common misconception that the flywheel key locks the flywheel to the crankshaft. That is not at all true. It only locates the flywheel for proper timing (in this instance). The taper on the crankshaft is what holds the flywheel in place. In olden days, racers would leave the key completely out of there hotrodded L head engines. As long as the flywheel was sufficiently tight you did not even need one. This allowed operators to change the timing of the engine to whatever their heart desired.
Chris
That is quite a little hedge trimmer. I wonder if someone hit a chain link fence or something hard and steel with the trimmer head, in turn breaking the connecting rod. It looks like the damage occured while it was running, and not just a sawing operation to separate the parts. Very cool project. I have been trying to find a Little Wonder with an O&R for the longest time.
Chris
Get out!, that O&R was really pushing that canoe right along! A video like that can make a believer out of anyone. Very very cool, thank you for sharing.
Chris
This site is dangerous. Every time I login I see all of these 'new' O&R powered machines I have never seen before. I think I 'need' to step up my O&R game. That winch is adorable. How useful it would be is left to your imagination, but it would be pretty badass on a power wheels or something like that.
Chris
Wow, an O&R on a multiuse demo saw. That is a new one for me. I wonder how well that worked out. I bet tile contractors loved them. It looks like it powers a ~ 7 or 8 inch grinder wheel. I have a much larger demo saw built by Racine for cutting railroad rail. The 10.5hp West Bend 820 engine turns whatever metal you put in front of the 16 inch abrasive wheel into powder. I would actually love to find one of these mini demo-saws. Its just too cute!
Chris
My Comet C-SAW has turned 60 years of age, and I thought that there would be no better present for it than to finally install the new diaphragm gasket I picked up from Wallfish a year and a half ago in Worcester. The old diaphragm was hard and brittle and simply beyond use. I was able to limp it along these last few months by removing it, soaking it in light machine oil, and reinstalling it wet. With the new diaphragm installed the little O&R started up and ran just perfectly. You can hear the little air vane governor working as it powers its way through some wood I had laying about.
Chris
That is so cool, I have never seen or heard of one of these before. Does anyone have a working example? I would so love to see one of these inflating a tire or charging a small air tank. I am a bit surprised at the 1700rpm compressor speed. That is awfully fast. The piston in the compressor must be smaller than what the O&R has....Very very cool. Now I need to add one of these to my want list. Sears sold a Power Products two cylinder engine which was half air compressor back in the 1950s. It was the smallest gas powered air compressor I heard of until I saw this.
Chris
That model F is gorgeous, a true time capsule piece. I have seen a lot of NOS units come up for sale that were not so well taken care of. It does not look like it will take much to get that nice early engine running again. With that gear ratio it should have a whopping 5lb/ft of torque on the output shaft. Any idea what it powered?
Chris
I have physically seen the King Portable Power Tree Tapper before, it is quite the setup for tapping trees
Chris
My G.H. Grimm is sadly not as intriguing, it is literally a backpack frame and an engine with a Jacobs chuck on it. It must have been the poor mans model of the King tapper. If this did not have a G.H. Grimm tag on it I would have chalked it up a homemade.
Chris
Did the previous owner say if it had a string head, a circular saw or a mower blade for trimming? I have a few weed whackers from the 1950s and circular saws were the latest and greatest in trimming technology. I am not sure when the first string head came about. The O&R certainly had the rpm to run a trimmer head, but maybe not the power. Bunton had a small machine setup like this with a vertical shaft power products engine and a small mower blade, maybe 8 or 9 inches. My oldest trimmer is a 1951 Hoffco Scythette with a 40cc west bend engine. It runs a ~20 inch sickle mower on two little wheels. The oldest string trimmer head I have is another Hoffco but with a 95cc west bend engine, built around 1958.
Chris
That is really neat. I have a G.H. Grimm tree tapper. It is nothing more than a backpack frame and a Power Products AH-36 engine with a Jacobs chuck on the crankshaft. I gather that this was a two person operation and the guy wearing the backpack was directed backwards to drill the trees by his partner. At 1.5hp it sounds sufficient in power. I did not know that there was an O&R gas powered drill other than the Drillgine. I have heard of a Homelite XL-12 powered drill, but I have never seen one.
Chris
Did O&R ever make a blade saw, which used the piston to actuate the saw? I have this piston in my collection, and it is identical to what Wright used in their blade saws, except that it is one half of the size in all dimensions. Surely someone else made a smaller blade saw that used this piston, just what it is, I do not know. There are no numbers stamped or cast into the piston. The piston is 1-1/4" o.d., the same as the later O&R engines. The thick rings are throwing me a curveball. I wonder if it is a salesman sample or something like that. If by any chance it is O&R, I would love to see what the machine looked like.
Chris
