forgot to mention that i have fitted a new tyre (well one that i found at the back of the shed) and actually taken it for proper spin up the road to my boss's workshop, bout a 1/2 mile! however i'm still in need of an idler pulley for the clutch and funds are too tight at the moment to get one so that parts on hold for a while the one that is on their is kinda alright for moving it round the workshop though
breif update, no pics at the moment, as my phone had an argument with a roller-mill :L have shortened some track end rods off an old c120 i have parked in the field so the steering is now completely functional, made a new clutch control rod and fitted a brake band scavenged off the same c120, sadly found a hairline crack in the gearbox, but jb welded it this evening so hopefully that will cure it, hitch pin is being a b&$T£*d so thats not really moved yet, started drilling it but its still holding fast so will try the gas on it tommorow! i'll dig the girlfreinds camera out then and take some piccies!
if threres no spark its most likely just gonna be a case of cleaning and re-gapping the points, check the plug is functioning of course, if that fails, move on to checking coil and condenser, its also really easy to convert a briggs to electronic ignition if you want to go down that route.
the hoods actually is quite good rust wise, but some one has cut a hole out in order to fit some sort of hand winch, my theory was someone used it for tree work, , have toyed with the idea of keeping the winch as its part of the history of this 604 and whatever it did though its working life......
well, had a bit of a session this morning, free'ed up the steering drop arms with some help from a blow lamp and some wd40, greased them and they now move as free as a bird, steering column is still a bit tight, (some sort of bronze/brass bushing in there?) rear panel work is off, not one bolt would undo despite 2 days soaking in penetrating fluid and 3 in 1 oil, they have all sheared despite my best efforts, so will be drilling and re-tapping a lot during reassembly! the clutch mechanism is now working with the exception of the return spring and idler pulley, the bearing in this is stuck solid and the pulley "V" has rotted out in places. Had a brief look at the slot hitch and this is rusted solid, anyone got any tips on how get the pin out without damaging the gearbox or hitch?
not too bad.....bit milky of course....but not awful....no worse than the c-120s when i bought them, have filled it with a mix of coca cola anddiesel at the moment, to flush it out a bit.
now theirs an idea,i think i'v got some in the shed........might keep costs down. seriously though i am giving the owatrol some serious thought
gearbox is now free.....i can push it around which makes life easier, in theory with a new drive belt and the clutch mechanism repaired its drivable (in the roughest sense of the word) all that appeared to be wrong wrong was that the brake mechanism had welded itself together with corrosion, the band is completely shot as is the lining so one of those needs to be sourced, but i'm gonna start on the clutch mechanism tomorrow or the steering..
she lives! :Dreground valves, tank and carb cleaned and a new spark plug, and after 26 yrs she ran this evening......runs sweetly and smooth....gearbox to tackle next!
first jobs gonna be getting it moving under its own power, then we shall see, the bonnets got a lovely patina, but the the wings and battery tray need some welding work done so it'll probally be a full respray job, plus i have never owned a nice shiny one so this might be my chance
well after a 5 hr drive, and some interesting moments loading and unloading from the back of a disco! this is now parked in my garden. at a first glance its a little daunting, but the engine turns over and the carb and tank is spotless. full set of wheel weights and the gearbox appears to work but the clutch and brake pedals are seized solid, the brake pads have rusted to the drum and the clutch linkage and steering rods are gone, thottle and choke cables have had it, the slot hitch is seized solid and lift rod has rusted though as has the battery tray! however it was love at first sight and she will be saved ! if anyones got a kohler 141 workshop manual they could email me i would be eternally grateful, and if anyones got any of the bits missing that were listed above and are willing to part company please let me know cheers
ashcombe scuffle was this week end, they always do a video of the weekend, and i managed to get in this one for once, i'm in it form 6.12 onwards, cracking day, great bit of fun! and the old series still showed it can hold its own!
with regards to the angle of the discs, larger agricultural sets of a modern design are adjustable for different tasks, the sharper the angle the more aggressive the action, this is caused by the vibrating action of the discs, faster you go the better they work, this is for gaining a fine tilth. Setting the discs to no angle so they are straight is used for primary cultivations to chop fibrous matter up. Reversing the angle of the discs on a smaller set you can use them as a very basic bed former to throw soil into ridges, on dual sets you have the front set pointing forward and the rear set pointing backwards, this means the front set throws the soil out and the rear set pulls it back in resulting in a level fine seed bed.
Just another day my work rig, Massey 7480 dyna VT and 5 furrow dowdeswell
be impossible to plough with due to that, and the gearing, be alright as a tug though
kohler engined triple mowers made in the 80s i think, well made and high geared, used for cutting semi rough and aprons on golf courses, simular to a national triple but more tractory in appearance.
Peat knife? Or a bizarre design of slasher?
ive got one, if you want it, buts its off a 2 hp, 90% sure its the same flywheel as the 3hp, pm me
looks like it woundnt pull the skin off a bowl of custard to be honest! suprised it can turn the oversize wheels, it looks like a 2hp honda, plus because he's changed the engine it wont run pto attachments anymore, the bonnets been hacked for the fuel filler, andf the thottle levers been bodged , but these are just points to haggle the price down with, i've bought worse!
that engine looks way underpowered for it!
someone trying to make bio-fuel with leaves
corroded points would be my guess if you hav'nt already checked them
I had a mate with a international scout, idiot cut it it up for scrap in 2010, it wasnt past saving either
