Stormin 4,458 #1 Posted August 5, 2014 Went over to the widows across the green today, to cut her large expanse of grass as her Snapper ride on is in dock. Just got nicely going, when the cutter deck lost drive. The bearing in the v pulley has disintegrated. Luckily I had the one that came with the C-81 on the shelf, so I continued with that. Cheap, rubbish idea for the pulley in my estimation. Bearing integral with the pulley. Could be a mod coming up. Share this post Link to post Share on other sites
Anglo Traction 1,018 #2 Posted August 5, 2014 Did a search for those Bearings a while back and they appear to be only available in the U.S. and lots of dosh to get 'em over to here. Only nearest size I could find in UK was narrower and so presume weaker?. Thought the same as you about modifying to take larger diameter and double row when necessary. Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted August 5, 2014 I'm thinking, machine out the centre and weld in a sleeve to take a slightly wider bearing, held with circlips. Share this post Link to post Share on other sites
meadowfield 1,901 #4 Posted August 5, 2014 You can split them by drilling out the welds. It's just getting the right bearing from then on... Share this post Link to post Share on other sites
the showman 4,074 #5 Posted August 5, 2014 Got half a dozen mules in the shed Norm if that's any help Share this post Link to post Share on other sites
Stormin 4,458 #6 Posted August 5, 2014 Thought you might. Bring a set to Newby. 1 diggerjames reacted to this Share this post Link to post Share on other sites
