grumps 2 #1 Posted June 25, 2015 Hi Everyone. Does any have or know where I can get a con rod for my 11hp B&S engine for my B115. It needs to be 30th oversize, They still make 20th oversize but not 30th anymore, Any help would much appreciated. Regards Grumps (Colin) Share this post Link to post Share on other sites
Chris 642 #2 Posted June 25, 2015 Think your best bet is another engine Share this post Link to post Share on other sites
HeadExam 1,783 #3 Posted June 26, 2015 Have the crank built up and turned? Share this post Link to post Share on other sites
ranger 373 #4 Posted June 26, 2015 What happened to the original rod ? did it break or is it worn out ? If worn you could bore it slightly larger,and then possibly 'white metal' it, bore to just undersize then scrape to a fit. Try 'googling' re- metalling bearings and 'Babbit' metal.If you have a fairly accurate drill press,and a bearing scraper you could probably manage without the use of a lathe or mill. Doug 1 HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted June 27, 2015 Where abouts in North York's are you, Colin? I've an 11hp Briggs sitting in my workshop surplus to requirements. Share this post Link to post Share on other sites
grumps 2 #6 Posted June 28, 2015 Hi everyone. Many thanks for your replies. The engine seized because I forgot to check the oil. I took the engine apart and separated the con rod from the crank after a struggle, I then managed to dig the bits of metal from the con rod, polished the crank and con rod. (I know it's not the right way to do things) anyway it felt pretty good so I put it all back together. It runs O K and is not making any noises, did 2 hours mowing on Saturday, no problems. I don't know how long it will last though. I will bear in mind your 11hp B&S Stormin as I think I might need it one day. Regards Grumps. 1 nigel reacted to this Share this post Link to post Share on other sites
