the showman 4,074 #1 Posted August 5, 2015 Most of the Wheehorse's i have the rear pin rusts up and they won't come out to change the hitch or split the tranny. Here's one i did this morning on a tractor that i want to take to RPT. It takes me just over an hour with several drill bits and a lot of drilling 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted August 5, 2015 You've forgotten to put the spacers on. When you think about it, it wouldn't be a bad idea to fit a grease nipple on there. Share this post Link to post Share on other sites
bubbalove 54 #3 Posted August 5, 2015 I must be very lucky I had to remove mine so I could connect rotovator just took the clip off 1 side and taped the pin out the other side I think lord wheel horse was looking down on me that day Share this post Link to post Share on other sites
C-101plowerpower 548 #4 Posted August 5, 2015 haven't had a problem with mine either, just take the clip of and pull it out by hand Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted August 5, 2015 I'd to drill the one on the C-125 out, but the C-121 gave no problem. I use the same type of pin as in Chris's photo. Much easier when changing hitches. Speaking of which, I'll be taking the two below to RPT. One is spoken for but the other is up for grabs. They go in a slot hitch. 4 the showman, Triumph66, sten and 1 other reacted to this Share this post Link to post Share on other sites
the showman 4,074 #6 Posted August 5, 2015 I'd to drill the one on the C-125 out, but the C-121 gave no problem. I use the same type of pin as in Chris's photo. Much easier when changing hitches. Speaking of which, I'll be taking the two below to RPT. One is spoken for but the other is up for grabs. They go in a slot hitch. 2002-05-31 00.45.41.jpg Core they look nice, you've made a good job of those, wish ide painted my hitch now Share this post Link to post Share on other sites
Stormin 4,458 #7 Posted August 5, 2015 You've time. Mind, the paint looks better in the photo. Share this post Link to post Share on other sites
