The Fife Plooman
Dunlop 700x12 argri tyres
Hi All
I have two tyres for sale as new with tubes swapped for rotovator thinking they would fit my Gutbrod 1032 ,will fit rims but will not fit under mud guards hence they must go £80 for pair  plus postage
Thank you
Based in Scotland
Sizes like 6-12, 7-12 and 8-16 are not like the normal 23x8.50-12 or 23x10.50-12, these tires are taller and I think the aspect ratio is the tread not the carcass of the tire. So these tires are probably a little larger than you might think.
6 minutes ago, Stormin said:
I'm wondering if they'll fit the Black Horse? Slightly narrower section may help when ploughing. I could raise the  fender a bit.
i think they will, i believe someone on here has them on a wheel horse
I've got them on the back of my C121, just got to put the 4.00 x 10 tri ribs on the front when I get time.
I cant wait to see the C121, I bet you will have good ground clerance
Driving my 312-8 with 10.5's feels as if I'm on a go-cart, on the C121, it feels as if I'm on top of an elephant:D
good ground clearance, tyres / tires are on standard rims- too wide, but I bought 4 more new tyres and narrow wheels from the sale for £100.00p :hide:  5 stud wheels but pcd is 1/4" different :( got 2 6x12's as well ;)
