neil 524 #1 Posted February 1, 2014 I have some new decals to install , what are the best ways to remove old decals & what is the best method to apply new decals ?, without getting those horrid bubbles Share this post Link to post Share on other sites
TITCH 84 #2 Posted February 1, 2014 Have you tried using an old hair drier or a heat gun to warm up the old decals, this will help soften the adhesive on the back. Any residue left you can clean off with meths/thinners or petrol... How big are the new ones and what are they Neil?? Some people like to use a slightly soapy water mix to help get them in position.... Titch 2 S1g and Anglo Traction reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #3 Posted February 1, 2014 Yup, Both work for me! Big decals, soapy water, they slide into place Share this post Link to post Share on other sites
neil 524 #4 Posted February 1, 2014 I am trying to apply resonable sized decals , so will try the soapy water method Thanx chaps Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted February 1, 2014 Soapy water and a bank/credit card for me. Share this post Link to post Share on other sites
Anglo Traction 1,018 #6 Posted February 1, 2014 Yep! , If you are not familiar with applying these , Follow the advice above. Your surfaces must be smooth, thoroughly cleaned and degreased first and wiped over with a Tack Rag to remove dust and reduce static. I prefer to apply them Dry, taping in place and removing a section of the backing at a time and pressing and spreading out in a particular way using a semi rigid Roller. 1 neil reacted to this Share this post Link to post Share on other sites
